Help Replacing 18" Driver in Reflex Cabs
Old 11th January 2019, 11:09 AM   #11
AliMOe is offline AliMOe
Originally Posted by ErnieM View Post
The JBL's will be an upgrade regardless of the exact specs.
The BMS 18S430v2, RCF 18X401, Oberton 18XB1300, and the Beyma 18PWB1000Fe are the best value high performance drivers at Blue Aran.
Thanks for the tips, they all look pretty good. Unfortunately I think I might be stuck with the jbl's for now.
Old 11th January 2019, 11:18 AM   #12
Originally Posted by chris661 View Post
Not necessarily.
You need to run some simulations (WinISD Pro or Hornresp) and find out what port tuning frequency would work best for your drivers in that size cabinet.
Chris
Thanks Chris.
Yes I realise now that what I should have done is run a load of tests with the cab/tuning to see what would work best oh well you live an learn (hopefully)
Well it looks like tuning the cab to 38hz would preduce the flattest response.
with the cabs at 40 there is a bit of a peak around 50hz (+1db)
Is this worth worrying about. how difficult would it be to adjust the port to tune to 38hz? is it something that's best fixed with some eq'ing?
Old 11th January 2019, 12:25 PM   #13
ErnieM is offline ErnieM  United States
I wouldn't worry about it all. Put a highpass filter around 30-35hz and Eq to taste.
Old 11th January 2019, 01:23 PM   #14
chris661 is offline chris661  United Kingdom
chris661's Avatar
Changing the port tuning frequency is a matter of woodwork, and making sure the additional port length (bear in mind it'll cut into the cabinet volume, so it can end up an iterative calculation) is well sealed to the rest of the cabinet.
I wouldn't bother. 40Hz extension is enough for most music. If you get a big-name EDM artist through your venue, it might be worth hiring in something that'll hit 25Hz with authority.
Chris
Old 12th January 2019, 04:48 PM   #15
Yeah, would be nice to have something that went a bit lower but maybe that will have to be a future project. Thanks for all the help / Kyle
Help Replacing 18" Driver in Reflex CabsHide this!Advertise here!
What is a good driver for these cabs? djn Full Range 16 1st December 2018 01:57 AM
Small Reflex Enclosure Mark Audio Alpair 12P 8" Ful Range Driver 92dB Abszero Swap Meet 0 25th March 2014 10:55 PM
Help with driver selection for tqwp cabs Milkduds Full Range 5 15th September 2012 12:54 PM
FR driver minitriangle cabs toobhed Full Range 3 15th May 2011 10:23 PM
Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) captainpabst Swap Meet 0 27th October 2006 11:01 PM
Copyright ©1999-2019 diyAudio
