4x 8" Subwoofer experiment.
Old 31st December 2018, 11:07 PM   #11
Dr1v3n is offline Dr1v3n  United States
Originally Posted by cspieker View Post
Measure what you have, then convert it to a well sealed design with one driver on each end with zero air leakage, then remeasure and listen. You will find it capable of much higher output and lower F3. What you have now is impossible to model and very unlikely to give good results. I think it's awesome that you just built it! But some modeling will give better results 99.999% of the time. Do have the TS parameters for the drivers? Get winisd and start playing around. Good luck! Craig
Thanks, I'll take that advice. I actually built them earlier this year. They have been in service for about 6 months. I'm very pleased with them, even more so now that they are individually amplified and EQ'd. The other day I was watching the movie Unbreakable in the background while working on the laptop. I heard nothing unusual but felt the laptop rattling underneath my hands. The 1 sub was about 10ft away against the wall far from a corner.
Here's a more current pic. It's more solid with a wider platform made from 2 layers of birch plywood glued together and 3 stabilizer bars, which are repurposed mop handles painted copper.
This is when I installed the MiniDSP Advanced 2x4 plug-in and was using a Plenue 1 audio player for the SPDIF digital source. Thins were not working initially which is why the 'scope is there...
Old 7th January 2019, 12:57 PM   #12
Last week I did some testing with REW and the Dayton mic placed in the center of the living room. The sub was about 5 ft away from the mic and any wall. Close to me so I could program the DSP. There was a dip from 40Hz-60Hz and a nasty peak at around 200Hz. And this was with a 48dB 150Hz LP filter on all 4. So I used the parametric EQ's to flatten it all out and it was good. This was with the sin sweeps from 10Hz-200Hz.
Next test was pink noise starting at low volume. Audio is coming from a computer SPDIF out straight to the miniDIGI/miniDSP boards then RCA out to the IRS2092S's. Slowly raising the volume, one of the amps gave out. Fans stopped blowing and no output. Thank God it didn't slam the output to one of the +_65V rails. It went quietly. Replaced the amp, after another one blew in the same position I am starting to suspect the errant SMPS that outputting +74V-60V but the other amp it is driving never blew out. Maybe coincidental? Replaced that amp, and did more stringent testing with no more blowouts. Was seeing output voltages of +-30V on the sin wave testing and close to +-20V on the pink noise tests. More testing today, with pics.
Today I will replace a resistor to increase the gain from around 40 to 46 in order to deal with the measly .9mV output from the DSP in order to try to maximize the outputs of these amps.
Old 9th January 2019, 01:11 AM   #13
cspieker is offline cspieker
Careful not to blow them trying to get a max spl in the current box setup. Very likely as soon as hear them in a properly sealed enclosure you won't look back.
Old 9th January 2019, 01:56 AM   #14
You're probably right. I need to take reasonably exacting measurements, SPL meter, 'scope measuring amp output voltage, REW w/cal'd mic. Next monday testing will be in session...
Old 12th January 2019, 09:55 AM   #15
WaVeInFoRm is offline WaVeInFoRm
I can see the theory here,
I would say as long as the inner drivers are sealed in well, it makes some sence to keep it as it is.
or you could build 2 more.. one for each wall
Old 12th January 2019, 07:08 PM   #16
Originally Posted by Dr1v3n View Post
The inner drivers have a gap of about 2mm equal from the ID of the PVC tube.
The outer drivers do have a 1/2" gap due to the way I currently have them mounted...
FYI. No seal anywhere. They are essentially 4 drivers operating in free space. With 2 out of phase with the other two. (he's operating the outer drivers in reverse polarity). I'm curious to see if the measurements are surprising. Always good to experiment, it's a very unusual setup. One would assume that the excursion would limit the output severely. Coupled with the cancelation from the reverse wired drivers...... The only unknown is what does an unsealed tube around the drivers do? If it does anything, it would only be at high excursion when there is significant resistance to air travel in that 2mm gap. It's an odd setup but once in awhile these experiments will teach us something, keep it up!
Old 13th January 2019, 11:36 AM   #17
FYI. No seal anywhere. They are essentially 4 drivers operating in free space. With 2 out of phase with the other two. (he's operating the outer drivers in reverse polarity)...
One correction: the 2 drivers on top are out of phase compared to the 2 on the bottom. Since I can do this very easily and quickly using DSP I tried all combo's. This current setup, I just explained, seriously increases the SPL compared to any other phase combo.
Old 13th January 2019, 03:07 PM   #18
Ahh, thanks for clarifying. It's strange that it would increase spl. At bass frequencies, with such long wavelengths, it should only increase output around the wavelength equal to twice the length of the tube (where the out of phase signals will be in phase again). Of course that's assuming drivers where the back wave is controlled in some way. In your set up, it shouldn't matter anyway because the back of the cone is another speaker radiating out of phase with the front. And the sound of the back of the cone is leaking out, meaning essentially you have 8 drivers total, with half of them out of phase with the other half, regardless of how you do the polarity. But there's still the unknown of the unsealed tube. Hope that makes sense. We'll see what the measurements look like compared to sealed.
Old 13th January 2019, 06:43 PM   #19
Frrom my memory at about 13Hz, I could feel the floor shaking. Drivers were moving about 2"pp. way more than the spec'd xmax of 25mm... It was a beautiful thing. I look forward to quantifying it all tomorrow. Hopefully no more amp blowouts.
Old 13th January 2019, 07:22 PM   #20
That makes sense actually. I think I know why now. With the top two drivers facing the opposite direction, wiring them in reverse polarity means they are pushing the enclosure in the same direction. You've made a tactile transducer for your floor!unfortunately, this is the opposite of what you generally want to do with a subwoofer. You want to hear the sound from the driver, not from the floor.
4x 8" Subwoofer experiment.Hide this!Advertise here!
Help the Ijit: experiment with "servo" sub Soldermizer Subwoofers 43 17th October 2014 03:34 AM
Thought Experiment Regarding Subwoofer Movement Along X, Y, and Z Axes SlunkBoy Subwoofers 1 21st November 2012 06:32 PM
"Quasi" ultralinear experiment - questions... Eusebius Tubes / Valves 8 11th July 2006 03:32 AM
Dayton BR-1 "experiment" and review. netgeek Multi-Way 20 4th June 2004 10:08 PM
Copyright ©1999-2019 diyAudio
