Driver Replacement for Yamaha Subwoofer
Old 7th December 2018, 06:50 PM   #11
Brian Steele is online now Brian Steele  Grenada
Originally Posted by Gwho View Post
Thank you for all the thoughts on the subwoofer. I will definitely try plugging the ports and see how they sound. Perhaps I will get more low frequency output using for of them.
gwho
If this subwoofer uses some sort of feedback loop to modify its output, plugging the ports is likely not going to produce good results.
I must do some more reading about this YST tech. Looks interesting...
www.diysubwoofers.org
Old 13th December 2018, 05:11 AM   #12
basreflex is offline basreflex  Spain
most likely the loop adds electronic mass to the driver to create a a lower Fs.
Old 19th December 2018, 09:09 AM   #13
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
... And then the question is: Can it be DIY'd easily?
Things are starting to happen, work in progress: https://kaffimann.com
Old 19th December 2018, 09:43 AM   #14
this yamaha uses the technique described by erik stahl , also discussed in this forum:
Simple MFB woofer project
Old 19th December 2018, 09:55 AM   #15
smichael is offline smichael
Karl Erik Stahl developed a technique where the amplifier is synthesizing some of the parameters of the driver used, most impotantly the moving mass AND the resistance of the voice-coil. With a negative output-impedance of the amplifier the eletrical Q of the driver is reduced, and the synthezised mass-increase is lowering the Fs without decreasing the efficiency.
The bottom line is that even with a new driver the amp will dominate the driver-parameters, which means that a new driver probably not will improve the performance, even if the circuit is calibrated to fit the new driver the best possible way.
Steen
Old 24th December 2018, 05:37 PM   #16
Gwho is offline Gwho  United States
Thank you all for the discussion, information, and thoughts. Merry Christmas and Happy Holidays to all. As I previously mentioned, I will use the Yamaha's as is or sell them. They do not sound bad at all when using four of them in a small room but they do not have the low frequency impact of larger subwoofers that I have heard.
gwho
Old 23rd January 2019, 09:18 PM   #17
brad1138 is offline brad1138  United States
Originally Posted by ParadiseComm View Post
If the mounting opening matches, I'd look at a GRS 10SW-4 driver. Anything more than that, you can be spending more on a replacement driver than the subwoofer is worth.
My Brother in Law just blew the driver in his 315. Should that be a good replacement driver? Should it sound, "more or less" as good as the original?
Thanks.
Old 23rd January 2019, 09:52 PM   #18
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Just from a quick read on the manual is it possible that you have simply trialed them with the cut-off set too low?
Setting the cut-off at 40hz the graphs indicate very reduced output
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 23rd January 2019, 10:20 PM   #19
He listens loud, and he says it started rattling loudly.
Old 24th January 2019, 01:55 AM   #20
Moondog55's Avatar
Where does he say that? I can't find that statement so I figure I must be missing something but "Rattling would indicate to me a poor join somewhere or loose screws perhaps
Driver Replacement for Yamaha SubwooferHide this!Advertise here!
Subwoofer driver replacement advice zartan Subwoofers 2 29th July 2012 07:37 PM
Yamaha C-85 Replacement Capacitors gni Solid State 82 13th February 2011 06:56 PM
Need a replacement 12" subwoofer driver chevy1965usa Subwoofers 0 26th December 2006 04:38 AM
Yamaha A400; bias too high after driver chip replacement hiwiho Solid State 24 30th December 2005 11:35 PM
Replacement Driver for Infinity RS Subwoofer Phillyguy Subwoofers 0 2nd January 2004 03:13 AM
Copyright ©1999-2019 diyAudio
