In-floor subwoofer s- 8x8" drivers each, highest WAF factor
You can definitely feel the air flow coming out of the vents. I placed the tower speakers so they stay on top of the vent covers otherwise the covers would rattle.
I measured the THD with the vent covers in place. Surprisingly the pressure drop around the vents did not create significant distortion.
No chaffing sound is coming from the vent covers for those test levels.
I did not measure the excursion of the drivers but it seemed around 0.8 Xmax. The subs are capable of around 6-8dB more before hitting the Xmech. The sound quality remains almost the same until it hits the Xmech.
The main strengths of that system are:
1. VERY VERY LOW THD - around 1% from 8Hz - 37Hz.
2. The subs are totally out of view and wife really happy about that.
OMG, I still can't believe those numbers given whatever the average mass market subs THD measurements are (10% and up).
I did the readings few times over just to make sure. Than I pulled out the RatShack meter and its SPL reading was +/-1dB from the REW readings - so the UMIC was OK.
The bass sound is Clean and Detailed - no matter if the music is playing at 100dB or 70dB - you can always hear the bass standing out especially when the sub sound starts/stops.
It sounds effortless, quick, clean, with authority, no lingering after the sound is gone.
You should read this page :
Phase distortion
"http://www.linkwitzlab.com/phs-dist.htm" :
Quote: "The waveforms of A, B and C above are quite different and it would not be unreasonable to expect that they sound different. Yet, I have not found a signal for which I can hear a difference. This seems to confirm Ohm's acoustic law that we do not hear waveform distortion. At least it seems to apply to the phase distortion generated by typical allpass crossovers."
So it's all good :)
OTOH the sharp cutoff is needed for:
1. Removing as much of the Main towers resonant port sound - it gradually does phase shifting the lower it goes towards port frequency.
2. Staying away from the subwoofer box resonant frequency Fb which is around 60Hz
... Unless you use FIR processing.
FIR can get you a system-wide delay but no phase wraps. For stereo playback, that can be very useful.
Chris
Yes. I plan on using all FIR filters for my Open Baffle line array.
Last year I tried FIR and wanted to see if I could hear artifacts of that process.
I set up (2) of the line array 4" drivers - RS 100T-8 - one in each channel. Than I did 96dB/oct Hanning window FIR at 400Hz (as far as I remember) in "rephase" and loaded it in MiniDSP.
On freq sweep I couldn't tell when the sound jumped from one driver to the other. No change in sound timber, etc. It worked great.
Even better - you can use "rephase" to straighten up the phase response of ANY existing speaker (multi-way with xovers, passive speaker, active speaker, etc) to 0 deg in the audio range as long as you know what your current phase curve is or you can "play it by the ear" while adjusting it.
The only penalty here is time delay - it's needed for signal spectrum evaluation and is proportional to the time period of the lowest frequency evaluated.
As far as I remember for a xover at 40Hz the time delay was around 60msec.
FIR and "rephase" are great tools for getting the max out of you system. I love it.
