Eminence Delta Pro 18 A in prism sealed 150 liters
Old 27th May 2019, 07:46 PM   #261
academia50 is offline academia50  Argentina
Do not be impatient, there are other prorities and first things first ...
Old 1st June 2019, 08:13 PM   #262
I found this SPL calculator.
After entering the data of this project, the result is excellent, but a question arises here.
Within the values to be introduced, the sensitivity of the speaker refers to 1 W / 1m) but, and the gain or loss of the cabinet?
It is not the same a bass reflex, horn or sealed, correct ?
Thoughts ?
File Type: png Calculo SPL Eminence Delta Pro 18 A.png (218.1 KB, 119 views)
Old 3rd June 2019, 03:36 PM   #263
David Morison is offline David Morison  Scotland
Thoughts ?
I think the writer of that tool expects this to be used for finished speakers with a flattish frequency response, thus one can expect there to be one sensitivity value that is a reasonable approximation of the whole speaker's response level.
Your project is a bit different in that you are accepting a loss in sensitivity as frequency decreases, so if I were you, I'd input whatever value corresponds to the expected sensitivity at the lowest frequency of interest rather than the nominal sensitivity which would only be relevant at higher frequencies. I thin that will be about 86dB for one speaker in your case.
HTH,
David.
Old 4th June 2019, 01:41 PM   #264
HTH,
David.
Sure help, thanks !
I will make the new calculations within the range I need, and upload them again.
I forgot the link, here goes :
Peak SPL Calculator
Old 4th June 2019, 09:24 PM   #265
Well, here the final results, two subwoofers of 18 inches, sealed cabinets of 150 liters and located in two corners.
Listening point 6 feet (4 meters).
I have drawn a graph for a quick comparison of the SPL obtained at 20,30, and 40 hertz, with 1 Watt and 250 Watts ....
Old 4th June 2019, 09:41 PM   #266
The rest ...
Old 5th June 2019, 04:47 AM   #267
Please, read:
40 hz 1 Watt , 92.80 Db at 6 ft.
I'm sorry, there was an error in the graph ...........
Old 12th June 2019, 07:17 AM   #268
Originally Posted by Lunchietey View Post
I built a fully braced tansmission line last week in 2 days(without paint time) and tested.
Well, we do not all have the same skills, congratulations for it !
All of these tiny braces etc will do very little, the box sides aren't that big and you're using low power anyway so the box flex will be minimal as is with such a thick baffle. The triangular braces would probably be plenty already.
The idea is to go to more power with DSP if the result is not as expected.
That's why I'm building the strongest possible box.
Also, the resale value will be better, would you be interested ?
Old 20th June 2019, 10:03 PM   #269
At last the sun has come back and today I advanced preparing the parts for the last reinforcement.
We had two simultaneous catastrophes, one is very well known here, it occurs minimally once a year, during a week followed by the city of Buenos Aires, fall on her the famous "sudestada", the sea wind coming from the south- east, works as a plug to the natural drainage of the Rio de la Plata, accompanied by copious rains and electrical storms, also raising the level of the river flooding the surrounding coasts .....
But the most worrying was to cope with this natural climatic phenomenon, accompanied by another unprecedented event, a tremendous blackout of electric power (never seen here, remember when something similar happened that affected the USA and Canada?).
So this time I have a good excuse for the people here who are asking me to hurry up the work!
How do you expect me to work under these conditions ?
Massive power outage hits Argentina, Uruguay
Apagon historico: otros cortes masivos de luz en el mundo
Old 13th July 2019, 11:30 PM   #270
I have finished the last reinforcements in the interior area of ​​the cabinet.
I was thinking that placing the speaker on the outside of the baffle panel will help to compensate a bit for the excess reinforcements. Anyway, a lot of stuffing will return things to their place, the big question is:
How much exactly? I think I remember an article about how to calculate it, but I'll have to dig into " Markers " of Win .....
If someone provides a link, it will be very appreciated
Eminence Delta Pro 18 A in prism sealed 150 litersHide this!Advertise here!
Two sub design options Eminence Lab 12 in 95 liters or Lab15 in 150 litres darkmatter Subwoofers 16 16th June 2018 04:34 PM
1st build: full range sealed for 4 liters zgtc Full Range 37 13th September 2017 11:32 AM
WTB: Eminence Delta Pro 12a Pollace Swap Meet 0 14th March 2015 08:19 AM
100 liters sealed. What sub driver goes the lowest?? jjkozlow Subwoofers 5 21st July 2005 07:14 AM
TC2+ in 60 liters sealed box ZACC Subwoofers 7 1st April 2005 05:00 PM
Copyright ©1999-2019 diyAudio
