best woofer for tham12, i tried with rcf midbass..
Old 20th July 2018, 10:54 AM   #1
angelodj is offline angelodj
Default best woofer for tham12, i tried with rcf midbass..
What is the cone that spins morein tham 12?
I recommend a woofer ch pushes well, I will use it with a powersoft of 1000w.
I did some tests:
I had a 500w Chinese class d module and a rcf mb12n351 at home, but the result is really poor!
comparing with the 12ps100 of martinsson the answer seems the same ..
but by simulating a 500w amplifier, things change, I think the 6mm excursion arrives
moreover, often if I do not go with a hard limiter, I hear pop maybe due to over-excursion ..
however, even the original b & c in the simulation has over excursions:
I simulated the 12hp1030, how do you think?
Old 20th July 2018, 03:05 PM   #2
Djim is offline Djim  Netherlands
It all starts with a correct model: LINK
Old 20th July 2018, 04:22 PM   #3
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
What are your input parameters to get this sim - As Djim suggested try the input parameters in the link
The results you are showing suggest that this tiny box and driver will produce 122 - 126dB
with the limits you have set - What is it about that result that you consider poor?
Old 20th July 2018, 05:06 PM   #4
I used the parameters taken from the blog of mr. Martinsson:
I noticed that compared to the link you posted they are different!
I think the simulated db are not there at all, it will be the fault of the Chinese amplifier? or is it the inadequate cone?
I use the bass section of this amplifier:
Bordo Amplificatore Altoparlante a 2 vie gamma completa RMS 600 W Classe D Amplificatore Piastra Costruito in modulo DSP con Alluminio radiatore in Bordo Amplificatore Altoparlante a 2 vie gamma completa RMS 600 W Classe D Amplificatore Piastra Costruito in modulo DSP con Alluminio radiatoreda Amplificatore su AliExpress.com | Gruppo Alibaba
Old 20th July 2018, 05:33 PM   #5
I simulated with the table of your post (but I put 2.83v)
Old 20th July 2018, 06:47 PM   #6
Xoc1's Avatar
You have not got all the settings correct It looks like you have the horn type set to ND rather than TH. You have shown the screen grab from Martinsons Blog not your actual input screen. Also note that in the blog the setting is 1Pi not 2Pi. showing a cabinet used against a back wall as well as being on the floor.
Old 20th July 2018, 07:16 PM   #7
Xoc1's Avatar
Hornresp seems to show that with the RCF MB12N351 xmax 6mm will be reached at about 44.72V - (Nominal 250 W into 8 ohms) 294W into the driver at 50hz, Using a 4th order butterworth hi pass set at 40Hz.
This does not take account of any headroom for the amplifier or thermal compression in the driver.
Old 20th July 2018, 08:49 PM   #8
my input data:
I used a 2xpi simulation because it's more realistic, should it be the standard that companies use to declare data?
Old 20th July 2018, 09:30 PM   #9
Xoc1's Avatar
As I said you are not simulating a tapped horn Where it says Nd it needs to be TH
(Click on the Nd text to change it until it reads TH) the rest of the parameters look OK to me.
Old 20th July 2018, 09:38 PM   #10
you're right, I missed that parameter!
here is the right simulation
do you think the fault in the lack of thrust resides in the amplifier?
best woofer for tham12, i tried with rcf midbass..Hide this!Advertise here!
Usher S-520 woofer/midbass problems? treuben Multi-Way 0 11th February 2017 06:19 PM
compromise = small woofer - larger (horn) midbass - what woofer types blend well? freddi Multi-Way 1 31st October 2015 01:15 PM
Just looking for the perfect 5.5" midbass / woofer hukkfinn Multi-Way 24 17th July 2012 03:17 AM
Which midbass woofer for TL? CharlieM Subwoofers 7 17th November 2010 09:10 PM
Sweet little $15 Woofer/Midbass discreteouts Multi-Way 21 30th March 2008 01:24 AM
