Here's my set-up
Denon AVR-687 circa 2005
Canton 12" Plus C passive sub. Front mains wired through the sub
Focal Chorus 807 V fronts
Focal Chorus CC 600 center
Canton GL 260 satelites
Rectilinear 3 Lowboys running as main rears circa 1973
I'm adding a small active Wharfedale sub. My AVR is set to SUB OFF so I can use the passive sub. Will the LFE connection from the AVR to the active sub work if it is turned to SUB OFF? How should I wire this so that I can use both active and passive subs at the same time??
