Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/builds
Thread Tools
Old 9th June 2021, 09:42 PM   #1231
resko1 is offline resko1  United States
Originally Posted by BP1Fanatic View Post
Nice rig!
Thanks man! Going to be building two more shortly.
Old 20th June 2021, 03:40 PM   #1232
johnnyjo is offline johnnyjo
Has there been any development on the 4x8 inch cab? I can't seem to find any additional postings showing plans or builds.
Old 22nd June 2021, 04:32 PM   #1233
zigguratSound is offline zigguratSound  United States
zigguratSound's Avatar
Handful of pics/vids from over the weekend with the two completed Type C cabs.
The sound is fantastic. I went hog wild with the measurement mic on top of a hill in Morro Bay last weekend. Frequency response is exactly what was advertised and it was really easy to EQ and integrate with the rest of the system. There was a big cancellation happening between the paraflex and the kick and once I added the right delay settings every kick drum felt like being jabbed in the sternum with a boxing glove when standing close to a stack. Excursion was under control all night even with huge bass drops that went very low. They are also surprisingly directional so when we pointed them towards a hill we were on instead of the valley below us it made a substantial difference.
Old 22nd June 2021, 05:59 PM   #1234
LORDSANSUI is offline LORDSANSUI  Brazil
Grants for the work zigguratSound.
Looking to the picture looks like you system is 4-way, is it right?
In general digital processors works with 3 way system, so maybe your tops are using a passive crossover and you feed them with 1 way (top).
Bass = 1 way
kick = 1 Way
Top = 1 Way (split 2-ways passively)
Old 22nd June 2021, 06:03 PM   #1235
In addition, could you share you experience and thoughts why you choose these configuration?
If you eliminate you kick and just use your sub-woofer and tops, what would you system lacks? aren't your tops capable to go low to 100Hz ?
Old 22nd June 2021, 07:07 PM   #1236
Good question. The system is 4-way active. We use a DBX driverack to split everything three-way and the 20hz-250hz band gets split again between the kicks and the subs by running that signal into a Behringer crossover. I can only imagine the biggest signal degradation happens there as a result, but the bass sounds OK to me.
If anyone can recommend a logical next step to migrating away from the Behringer, I'd love to hear it.
The tops can reach around 100 hz but the ports are in the back. I built them this way with the expectation that we could just run them at patio BBQs without needing any kicks, just a pair of 15" bass reflex subs.
I opt for the kicks outdoors because they make the rig taller, give us more dispersion control for those frequencies, and take a big load off of the mids. With a taller rig, we still have the kick frequencies at chest height, and everyone can still hear the mids and highs with good clarity even if a tall-ish man walks in front of a stack.
There's also my own dumb-guy reasoning that everything looks cooler this way and we have more surfaces to light up. I'm not ashamed to admit it.
Old 22nd June 2021, 08:25 PM   #1237
thanks for you feedback
Old 22nd June 2021, 10:34 PM   #1238
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
Hi zig.
I guess you don't want to run mono eh?
I have a dcx 2496 and run it mono for 4 way.
NO REST FOR THE WOOFER! 🔊😈
Old 22nd June 2021, 11:21 PM   #1239
Nice, it's good to know that's an option. I'm fine with mono tbh and love to run speakers in a big stack. The crew played some tracks over the weekend though that sounded really trippy when we got to experience the way the producers panned certain sounds and it was a lot of fun.
I don't think the DBX unit I have provides the ability to output 4-way mono but I've been thinking about picking up a used behringer DSP just because. Does it have a decent iOS app? that's a nice perk of the DBX. My wife was playing lots of house music with very bright-sounding disco vocal samples and I was able to walk around the dance floor with a tablet listening to the mids and figuring out how best to attenuate them for her set.
e: here's another pic of the stacks in my living room since I'm here
Old 22nd June 2021, 11:22 PM   #1240
Top Shelf's Avatar
Hi Zig.
If you have the pa 260 you could run 2 channels for stereo tweets, 2 channels for
Stereo mids and use 1 channel for mono kicks and 1 channel for mono subs.
Just a thought.
Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/buildsHide this!Advertise here!
Thread Tools
Can you use 2x 4th order BP boxes to imitate a 6th order BP ? RobWells Subwoofers 26 9th March 2012 08:33 PM
Compound horns, anyone? brsanko Full Range 30 15th August 2011 02:15 AM
6th order bandpass question tinitus Subwoofers 13 8th March 2009 06:01 PM
6th order bandpass Chris8sirhC Subwoofers 1 13th September 2008 07:09 PM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
