U-baffle H-baffle W, N baffle Ripole etc..: which works the best close to the wall??
Old 3rd January 2017, 12:32 PM   #1
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
Default U-baffle H-baffle W, N baffle Ripole etc..: which works the best close to the wall??
Hello I would like to build two ripole, or two H-pole by using one or two Eminence 15'' woofer per buffle
My problem is that I can collocate them (the idea is two buffles) only close to the wall, or worst, in a corner. So I'm asking which is the best small open buffle construction that works the best close to the wall or in a corner.
They must be hight max 50 cm, too.. as I have a wife...
I would like to cut them at around 60Hz, because above I have already my loudspeakers, which I would like to reinforce just at 25-50Hz.
Old 3rd January 2017, 12:40 PM   #2
S4m is offline S4m  Germany
S4m's Avatar
Close to a wall, i would say asimple baffle without Ri|U|H...
Much better and probably easier would be a sealed woofer or a corner-horn
It's more or less a table in the corner for putting some plants or nice decoration stuff ;D
Here a page from a german guy who created a simple corner solution: eckhorn.html
Old 3rd January 2017, 01:59 PM   #3
Face is offline Face  United States
Face's Avatar
+1...
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 3rd January 2017, 02:07 PM   #4
Kjeldsen is offline Kjeldsen  Denmark
close to a side-wall but 1 meter to backwall is not an issue. But 25 Hz with just one 15" will be an issue, unless you don't play very loud.
If you must place speaker in corner or very close to back-wall then OB is not a good typology. As suggested already - try a closed box in cornerplacement, and use some eq to get a good flat frequency from 25 - 50 Hz.
I have small OB box in U baffle, and they have to be at least 1 meter from back-wall if you measure from the front of the speaker. If I listen more serious I will move them even more out in the room.
http://kjeldsensforbindelser.dk
Old 3rd January 2017, 02:17 PM   #5
Face's Avatar
A sealed Dayton UM18 in 4cf+ would have no problem with those frequencies and will be happy against the wall.
Old 3rd January 2017, 06:19 PM   #6
chris661 is offline chris661  United Kingdom
chris661's Avatar
Its possible, but you're gonna need a good 15".
I used Beyma 15P1200Nd open baffle (one per side) for a short while, and 30mm p/p travel happened fairly often, though it was louder than I'd normally listen.
Chris
Old 3rd January 2017, 07:22 PM   #7
I do have a good 15" with very long Xmax (+/- 15 mm linear travel). And yes, it can be fairly loud. But deep organ or electronic like Trentemøller with very low frequencies at high volume, and you will meet the limit before it's very loud. If you sometimes like it loud, then you will miss it. If you don't then 15 inch with long linear Xmax is just fine.
Old 4th January 2017, 08:33 PM   #8
Chris
Beyma 15P1200Nd - Xmax is 9,5 mm = 19 mm p/p linear, but it does have impressive 52 mm X damage. Fs is quite high.
I will use two (I have only tested one at the moment) Gladen RS15FA. I am quite amazed with the quality of these drivers and the price is fairly low - around 190 €. It has very long linear travel (30 mm p/p), and very low mechanical noise even with long travel.
Old 5th January 2017, 03:11 PM   #9
chris661's Avatar
I EQ'd them flat to 25Hz. Any 15" driver will have to move the same amount to produce the same SPL (assuming the same baffle etc). Sounds like the Gladen driver has enough Xmax for what you need.
Chris
Old 6th January 2017, 06:23 AM   #10
yes but Ygg-it needs to know that you need at lot of power then (and DSP). In open baffle the frequency drops with 18 dB/oct below Fs (as far as I rememeber) . Down to Fs it will only be 6 dB./oct.
If you have a lot of power, then you can use almost any solid woofer with high Xmax. If you don't have lot of power you will need high Q woofer and preferable low Fs and high Vas. High Qt is easy - any cheap woofer will do that, but finding a quality woofer with high Qt, low Fs and high Vas can be a little hard. But, you need less power and correction for low Fs can be done with passive filter.
Just some of my rule of thumbs
U-baffle H-baffle W, N baffle Ripole etc..: which works the best close to the wall??Hide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 05:26 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 03:23 AM
JA8008/TWO34 open baffle/ripole project vankovich Multi-Way 51 27th October 2012 05:03 PM
Need help designing a new cabinet/baffle with proper driver to baffle placement. Big_Bill Multi-Way 17 16th June 2010 05:34 AM
Open baffle VERY close to back wall? Fast1one Multi-Way 6 4th April 2009 08:01 PM
Copyright ©1999-2019 diyAudio
