Twelve 12" driver dipole subwoofer build thread
Old 6th September 2015, 03:38 AM   #41
Davey is offline Davey  United States
Originally Posted by OldMike2 View Post
Charlie,
Have you seen Monte Kay's dipole sub woofers? There are some performance numbers on his site that give insight to some of the other questions on the thread.
http://http://www.mfk-projects.com/H...re_woofer.html
Correct link:
mfk-projects subwoofer
Dave.
Old 19th September 2015, 06:13 PM   #42
CharlieLaub is offline CharlieLaub  United States
Just a quick update on this project. It's been moved to the back burner while I focus on some other stuff that I need to get ready for Burning Amp. In the meantime I've made some progress with other stuff, namely my Raspberry Pi powered active speakers and streaming audio implementation. I'm now planning to use just a single Raspberry Pi 2 to implement the crossover for the sub and the satellites - that's a 6 or 7 output crossover. What these powerful little Pis can do is amazing.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 8th December 2015, 03:34 PM   #43
Ah, finally I have been able to put this thing into play, er sort of. I managed to feed one channel, low passed, from my crossover system to a outboard amp and connect up the sub. Wow, not the high sensitivity beast I was expecting... but once I added some gain and played around a little bit I do have some low, low bass. Luckily the entire first floor of my home has an open floor plan, so even though this is a dipole sub I get pretty extended response.
Old 14th December 2015, 12:34 AM   #44
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Twelve 12&quot; driver dipole subwoofer build thread
Look forward to your updates, Charlie!
Old 26th September 2018, 03:06 PM   #45
It's been a couple of years since I built this sub, and someone asked me to post an update so I will share the final info on it.
The sub has been dismantled (I moved >2000 miles to a new home). It was one of my early attempts at a large dipole sub, and it did have good low bass. The main problem was the line resonances (there were at least two or three). These resulted from the depth, with and height dimensions of the cavities in front and rear. Together they made the sub sound "boomy" and were difficult to EQ out or otherwise correct. The problem was the way I constructed the enclosure generated lots of different cavities of different sizes, and these all created various and sundry internal resonances at or below 100Hz.
What I have evolved to now is a large H-frame design with a single large driver. By "large" I mean the opening is on the order of 24"x24" (60cmx60cm) and the depth (front to back including both from and rear cavities) is also about 24", give or take. I employ an 18" sub with Qts>=0.4 (higher is better) and as high an efficiency as possible (e.g. using prosound drivers). This works pretty well, and there is only a single resonance from the identically sized front and rear cavities of the H-frame. I can just EQ it out as part of the low pass filter, e.g. around 100-150Hz or so, depending on where the resonance peak is located.
Because the H-frame is relatively wide and deep, I can still get good dipole bass from this system. The challenge is to reduce vibration to a minimum, which I do by making it very heavy. Sand-filled side panels are helpful in this regard, and something weighing well over 100lbs is needed if the driver's moving mass (e.g. Mms) is more than a few hundred grams.
I will eventually post about my latest efforts in this area. I'm not yet up and running after my move but maybe by springtime 2019.
Old 27th September 2018, 04:51 PM   #46
kazap is offline kazap
kazap's Avatar
Interesting evolution. Thanks for the update.
What do you think of the idea of packing four 12" drivers in a big 24"x24" H-frame like yours? It would give about 40% more SD and less vibration if drivers are mounted in opposition.
Old 2nd October 2018, 12:09 PM   #47
Yes on the idea of 4 12" drivers in a H-frame about 24x24 (or just large enough to fit them).
But I don't see how you will get any force cancellation... all the diaphragms must move in the same direction at the same time. You will probably get some even order distortion reduction with two of the drivers mounted "backwards".
The only way to mount the drivers to reduce vibration is for two pairs of two to face each other. This can't really be done in an H-frame. You have to resort to what I did for the 12 driver system, and that resulted in all of the resonance issues I mentioned. I would stick to the regular H-frame geometry.
Old 6th October 2018, 10:56 PM   #48
darkmatter is offline darkmatter  United Kingdom
darkmatter's Avatar
CharlieLaub I will follow the progress with interest, a friend is building two smaller (stereo pair) 4 12" per side units, I will see if he can chime in.
DM
Old 14th February 2019, 09:59 PM   #49
jccart is offline jccart
Reading this thread has made me wonder about a sealed design using this driver as an affordable experiment. My idea is two sealed subwoofers each using 8 of these drivers does anyone have any idea of an ideal size for a cabinet etc . I was thinking around 600 litres each ? Thanks in advance
Twelve 12&quot; driver dipole subwoofer build threadHide this!Advertise here!
DIY / Fine Art - Twelve Twelve Hundreds - A Turntable Exhibition - Technics 1210 nathanjh13 Analogue Source 1 18th January 2014 03:41 PM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
Need a replacement 12" subwoofer driver chevy1965usa Subwoofers 0 26th December 2006 03:38 AM
is there a infinite baffle 12 and 15" subwoofer thread ? zuki Subwoofers 9 28th July 2006 11:43 AM
Copyright ©1999-2019 diyAudio
