I did a TL design for a 55-2981. I don't have the plans on this computer but its a pretty small box... well I'm used to building 21" enclosures or dual 18"s. I have some pictures though:
This is the sub, max power:
Insides:
This is stacked this way because I was gluing the side on:
Insides:
Insides:
Is there any way you can provide the dimension (cut sheet, whatever information you have) on this?
I have been wanting to try a tapped horn like this, and for the price of the driver - its worth the price of admission.
Thanks.
I'm interested in one of those, too. Would it also be possible to get the Hornresp inputs?
A 12" version with a bit more output and similar extension would be perfect
Cheers
Chris
PS - are you sure that's a TH?
That's not a TH. It's a TL. Close, but not the same.
Interesting choice to rear-mount the driver. How do you get it out of the box?
Thanks Bjorno, that awesome!!.
The driver I have is a little different to the one you have used. Mine is a single 8 ohm vs the dual 4 Ohm you have used, will that make a difference?
I had a lot of trouble with the bump at 30hz, still a lot to learn.
Any hints on how to fold it?
Hi Beau,
I believe my T/S are correctly entered in HR ( I only changed Qms by taking a calculated value from Qts and Qes= a precaution consistency calculation).. but if you have an 8 Ohm variant, then BL must be doubled and Qes= Qes/2
b
If the Driver I've used is a dual 4 Ohm..then my T/S could also be wrong but I blame you who supported the Driver data.
Folding examples:
http://www.diyaudio.com/forums/subw...k-25w-8565-01-any-good-ideas.html#post3651001
- Subwoofers
- 10" Tapped horn Sub plans
