Driver at floor level or ceiling??
Thread Tools
Old 15th April 2012, 01:27 AM   #21
bjorno is offline bjorno  Sweden
R.I.P.
Send a message via MSN to bjorno
FYI, Tangband have drivers suitable for being mounted in-wall:s too:
b
Old 15th April 2012, 12:34 PM   #22
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Regarding placement, it's hard to say without testing it in your room. Here are some measurements for one particular room:
Red Spade Audio: Room measurement case study 1
(That is Mr Happy Pant's room)
In this example, two corner subs are similar in smoothness to a single sub in the centre of the front wall.
If you can install subs in the floor or ceiling, very much like you would with an IB, then it's even better (potentially) in terms of WAF. Then it can be very big. I've just installed a bit tapped horn under the floor. In my case I'm doing it dual opposed (it makes a big difference with vibrations) and then decoupling it from the structure by attaching the sub to the floor via poly foam filler.
  Reply to this post
Driver at floor level or ceiling??Hide this!Advertise here!
Thread Tools
Floor to Ceiling ESL ? Borat Planars & Exotics 26 12th February 2010 01:11 AM
MLTL driver/port placement, floor reinforcement etc... maxro Full Range 26 3rd July 2008 01:30 PM
Floor clearance for downfiring driver ? smallangryboy Subwoofers 7 5th February 2008 08:32 AM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
