Don't worry, breaking out an SS15 as advice was also meant with a little sarcasm. Btw you can easily use as much EQ you like with your SS15 to push some 40Hz tones cause that 30Hz filter of yours is good enough to hold 350watts under control (even if the driver didn't suffer from pwr/dyn compr.)nooo its not like i really need that much more low end, its fine really i guess im just used to hearing the effect of cabin gain in my car or hearing the songs played on multi hundred thousand dollar stereos in clubs lol
The last post in this thread is nearly 4 years ago. I imagine he's either fixed the issue or moved on at this point.Parts Express sells a speaker caulk that is kind of like window glazing, in little strips of rope. If your gaps aren't too big, that stuff will fill your voids, and it seals around handles and dish plates. Good Luck.
