Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 11th September 2015, 01:17 AM   #721
jaysinet is offline jaysinet  United States
What are most using for feet on these cabs? Like rubber pads, etc...to keep the cabs from walking the floor when playing.
Old 11th September 2015, 01:21 AM   #722
bjones is offline bjones  United States
I used the scrap birch to make 2 2in strips ran across the front and back. This made the front of the cab flush with the floor and appear seamless. From the side it gives you the perfect slot and height to slide in a dolly without needing to tip the cab (actually convenient if it's already butted against the next cab)
Old 11th September 2015, 01:22 AM   #723
Does your cab walk at all with just wood strips?
Old 11th September 2015, 09:04 AM   #724
$$Maan is offline $$Maan  Denmark
Originally Posted by weltersys View Post
From the OP:
Using Hornresp simulations at rated Xmax values, (and impedance minima) average level from 35-100 Hz, the Keystone has these output levels:
BC21SW152-4 131.6 dB, 92 volts, 3.4 ohms, 2489 watts
BC18SW115-4 130.1 dB, 76v, 3.43 ohms, 1683 watts
BC18TBW100-4 127.8 dB, 59v, 3.32 ohms, 1048 watts
How did you fit a 21" in there?
With the same box / compression?
I extended the depth of mine to 80cm to avoid too much compression, they sim something like 140dB! Never did any real world measurements though...
Old 11th September 2015, 01:15 PM   #725
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
He didn't. He said HR simulated results.
Old 11th September 2015, 06:25 PM   #726
Using only 2" wide strips forces all of the cabinets weight into a more specific area. The same reason snow tires are skinnier, they pizza cutter through the snow because the weight is not distributed over the wider tire. That's one reason sports cars will hydroplane so much faster.
Also, by going long ways with the face and back, the force will only be able to create a tipping motion. I am sure if they are placed on the sides going front to back it would still walk, because you essentially put it on skis, but there is no side to side energy only front and back.
Old 11th September 2015, 11:42 PM   #727
Thanks for the reply Bjones. I understand your analogy there, just seems like the plywood would be slick especially on something like a basketball gym floor for a dance or such. Made a lot more progress today on the builds. I have one cabinet with most of the braces and the horn baffle section put together. Everything is tight with the tolerances and going together great. I will snap some more pics and post them tomorrow when I get back to the shop. Just wanted to let everyone know I used a track saw to cut all the panels to size and every piece came out perfect. The track saws are wonderful, safe, accurate, and portable. If you haven't had the chance to use one, try it, you won't be disappointed. I own the Makita version.
Old 14th September 2015, 05:08 PM   #728
I have come along ways in last two nights of working on the cabinets. Both horn sections are done with all bracing. I took extra time making sure everything fit as tight as possible for each cabinet. I am going to run the wiring, mount the audio jack, button it up and install the last permanent side today. Then I guess I get to do some patching of screw holes and sanding of bondo...ugh!
Is there a best type and location to add some handles to this box to facilitate transport? Could I recess some of these in the back upper section, or do they remove too much material and cause sound/vibration issues?
http://www.amazon.com/Reliable-Hardw...049T2JHVP4BE4W
Old 14th September 2015, 05:29 PM   #729
Here is the second cab as of yesterday, they are farther along now, but newest pic I had to post.
Old 14th September 2015, 05:53 PM   #730
weltersys is offline weltersys  United States
weltersys's Avatar
The paddle handles with grips are generally vibration free. The back upper section would be an OK location.
Keystone Sub Using 18, 15, & 12 Inch SpeakersHide this!Advertise here!
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
Copyright ©1999-2019 diyAudio
