Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 5th August 2015, 01:47 AM   #611
blossom is offline blossom  New Zealand
blossom's Avatar
If stitcher’s are an option, choose to have them, they give a lot cleaner and smaller scar later. Big lumps of scar tissue on fingers and thumbs are annoying for years and years. If its a deep cut then oral antibiotics are a good choice as infection can lead to the larger scaring I just spoke about. This is just my personal experience, I am not a doctor.
Old 15th August 2015, 03:48 PM   #612
tetrapol is offline tetrapol  Spain
Default KEYSTONE NATURAL HORN (MODIFIED)
TAPPED NATURAL HORN WITH MEASURES OF KEYSTONE KEYSTONE PROJECT BUT NOT OUT .
Old 15th August 2015, 04:29 PM   #613
bjones is offline bjones  United States
So tomorrow I finally have some help to assemble the enclosures. Still another few weeks before I can use my hand. Studying the schematics it seems I would be best to build inside out. Starting with the horn and it's braces. Once the horn is shaped I was going to line it up on one side panel, trace its border, then clamp the 2 sides to each other a predrill then So the positions are identical. Then fasten the horn to the first side. Assembly the rest of the panels and finally add the second side. Install driver...then mouth panel. Any thoughts on this?
Old 15th August 2015, 05:29 PM   #614
weltersys is offline weltersys  United States
weltersys's Avatar
Sounds similar to the assembly I did, but I first loft the cabinet design full size on a sheet of cardboard so all parts can be checked for size and position. Drill holes in the cardboard for all the screw positions and use it for marking the left and right sides. Assemble the interior horn parts and braces, then attach the left side, top, bottom and front, then braces, then put on the right side.
Old 15th August 2015, 05:32 PM   #615
Thanks for the advice. I also picked up the dsp you suggested and it's running 24/7 with a low input into the drivers to get them a little ready.
Old 16th August 2015, 06:50 PM   #616
Are all the braces just placed equidistant to the closest adjacent brace/side?
Old 16th August 2015, 07:00 PM   #617
weltersys's Avatar
Photos of the cabinet interior are in Post #99 and clarification of the 9 braces used in #206 and #451.
Old 16th August 2015, 09:39 PM   #618
What hardware do you use to mount the driver?
Old 16th August 2015, 10:31 PM   #619
Ropes is offline Ropes  Australia
Default Underway
So picked up my BB Ply on the Friday night and started work.
I'm also building a set of sealed 18" mid bass drivers and a set of full range speakers (for a friends wedding gift) so lots to do.
Rowan
Old 17th August 2015, 12:54 AM   #620
Brian Steele is offline Brian Steele  Grenada
Rowan
What's the size of the speaker cutout in the baffle?
www.diysubwoofers.org
Keystone Sub Using 18, 15, & 12 Inch SpeakersHide this!Advertise here!
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
Copyright ©1999-2019 diyAudio
