Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 1st August 2014, 04:14 AM   #211
chappaj is offline chappaj  United States
ok downloaded rew. Is it possible to do the measurement with my with the interface I have. Steinburg ur44. I'm a little lost on how to wire this for test.
Old 1st August 2014, 11:21 PM   #212
spenserh is offline spenserh  Canada
I'll try to get some measurements on my Keystones in the next few weeks, I'm all tied up this weekend (human forklift for a One Direction show) and next (Mixing B Stage at a folk festival), but should have some free time to finish up my second cabinet and measure them.
Old 9th August 2014, 06:23 PM   #213
tralfaz is offline tralfaz  United States
Default My First Keystone Build
Getting closer to test of my first build. This is what I have so far. All my internal dimensions are within 1/8" to 3/16". The braces sure took me longer to fiddel in than I would have guessed....
I am going to try it out with a Peavey Low Rider 18 that I have on hand and see how it does.
Old 9th August 2014, 07:22 PM   #214
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by tralfaz View Post
Getting closer to test of my first build. The braces sure took me longer to fiddel in than I would have guessed....
Braces are a pain, but make a big difference.
Looking forward to you and Spenser's test results!
Old 10th August 2014, 06:34 PM   #215
Brian Steele is offline Brian Steele  Grenada
Hmm.. where's the mouth for the subwoofer in those pictures?
I wish I could get away with so little bracing for the plywood that's available here for subwoofer building. I basically bifurcated my last subwoofer all the way down to the last fold with a cross-brace, and still the top vibrates a bit more than I'd like. Doubling up on the thickness of the top panel didn't help much either.
www.diysubwoofers.org
Old 10th August 2014, 07:53 PM   #216
freddi is offline freddi  United States
freddi's Avatar
(guess that non-fixed panel will be the mouth panel) - hey Weltersys - what might be a good/inexpensive Keystone12 cabinet/driver combo?
Old 11th August 2014, 02:54 AM   #217
85audio is offline 85audio  United States
Default Keystone Sub
What would a double Radian 2216 Keystone cab look like? 6" wider and still fit through the door. Is the 2216 a candidate, 14lbs apiece, light weight and 21.3mm xmax! I know, expensive, right. Who cares, what can it do.
Old 11th August 2014, 02:58 AM   #218
sine143 is offline sine143  United States
maybe we would know if they would post a complete spec sheet....
Old 11th August 2014, 02:11 PM   #219
Had not yet cut out the "keystone" mouth. It goes top left.
I did finish one cab yesterday and a quick listen brought smiles to my face.
Kudos to weltersys for a great sounding design! I will attempt some measurements later this week and share what I observe.
Old 11th August 2014, 06:47 PM   #220
weltersys's Avatar
Freddi,
Two Lab 12s worked well, the results were posted in the OP. A single version could be made by reducing the width appropriately.
Keystone Sub Using 18, 15, & 12 Inch SpeakersHide this!Advertise here!
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 12:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 09:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 09:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 10:54 PM
Copyright ©1999-2019 diyAudio
