Keystone Sub Using 18, 15, & 12 Inch Speakers
Old 2nd June 2017, 06:50 AM   #1111
USRFobiwan is offline USRFobiwan
USRFobiwan's Avatar
Hi Osse, I suggest more bracing it is the resonance that make it move. I guess you are using the cabinets standing upwards?
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 2nd June 2017, 07:30 AM   #1112
Osse is offline Osse  Sweden
I braced them according to plan, even a little bit more.
I'm using them standing up yes! It's sad if I have to bring 20-30 kg weights to the gigs I can't use extenders.
Old 2nd June 2017, 08:37 AM   #1113
USRFobiwan's Avatar
I had the same problem with TH18 prototype standing up. First I did some more bracing and then I put some 'stone carriers' (rubber plates from recycled rubber) that helped a lot. i think you can find them at your local BAUHAUS Bäckebol. We use this a lot on our gigs.
looks like this:
Old 2nd June 2017, 09:47 AM   #1114
looks like this:
How big are those matrasses, do they cover the whole bottom or one in each corner? Thanks for the tips!
Old 2nd June 2017, 10:00 AM   #1115
USRFobiwan's Avatar
originally they are around 40x50cm slap (give or take) and then you can cut, or rather bend them to smaller pieces, it has crosscuts, 2/3 way through. form ons piece you can have 4x6 pieces of 12x20cm pp.
Old 2nd June 2017, 10:01 AM   #1116
blossom is offline blossom  New Zealand
blossom's Avatar
They look like recycled tyre(tire) rubber chips glued together to me??? In which case they would be fairly dense.... dense enough to add enough weight to weigh the cabinets down... hmmm....
Old 2nd June 2017, 10:08 AM   #1117
USRFobiwan's Avatar
yeah they are used to carry stone tiles so they can carry quite the loads. its really useful for rigs for putting under and between stacks of subs or tops. Add in the dampening factor on non slippery surface its a win win.
Old 2nd June 2017, 02:40 PM   #1118
I was just out and bought a package of the stone rubber feet, but they are small, 60x90 mm. Still much bigger surface than my current feet offcourse!
Hope it will solve the walking subs!
Old 2nd June 2017, 10:12 PM   #1119
Brian Steele is offline Brian Steele  Grenada
Have you tried raising the back of the sub with a strip of wood say about 1/2" high? Let the front edge of the sub rest on the ground. This should decouple the bottom panel from the ground and remove its vibrations as a cause of the "movement".
www.diysubwoofers.org
Old 2nd June 2017, 10:31 PM   #1120
djk is offline djk
R.I.P
djk's Avatar
"Hope it will solve the walking subs!"
PPSL mounting makes for subs that do not walk.
Candidates for the Darwin Award should not read this author.
Keystone Sub Using 18, 15, & 12 Inch SpeakersHide this!Advertise here!
Ne 5532 15+15 or 18+18 east electronics Solid State 3 26th January 2010 01:43 PM
Which amp for speakers with a Fountek Neo Pro 5i and 12 inch woofer boidos Pass Labs 1 24th June 2009 10:10 AM
Two 10"inch and two 12" inch subwoofers and what to do?? Gentle1Man Subwoofers 25 13th March 2008 10:00 AM
Two 8 inch usher vs one 12 inch M&K qguy Multi-Way 0 25th October 2006 11:54 PM
Copyright ©1999-2019 diyAudio
