C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
Old 21st October 2018, 04:37 PM   #991
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Has anyone tried fitting a 21 inch woofer in this enclosure?
Just playing around with the idea of building this enclosure as its easier to build than the Othorn.
Old 21st October 2018, 04:56 PM   #992
BP1Fanatic is online now BP1Fanatic  United States
BP1Fanatic's Avatar
Have you thought about refolding the Othorn?
Old 21st October 2018, 10:15 PM   #993
epa is offline epa  Netherlands
it could be made to suit an 21"
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 22nd October 2018, 01:32 AM   #994
CRESCENDO is offline CRESCENDO  United States
I started making a spacer ring a couple weeks ago to try just this. The original plan’s baffle is not deep enough — so, to prevent the driver frame from hanging out of the front of the cab, the spacer needs to be shifted off-center to the rear of the existing baffle and part of the 21” baffle cut-out ring needs to stay intact to prevent the driver from firing into the wrong part of the horn. The small part that stays intact needs to be routed/cut down to make clearance of the cone edge/surround under high drive levels. You can see some progress (I have more cutting to do) from two weeks ago (see attached). Also, my particular center brace needed quite a bit of modification to clear the bigger driver’s frame and magnet. I did not make my center brace from a cutsheet though, so you might have a different scenario.
Hi Erik! That might be pretty neat. The 21SW152 & 21DS115 sim similarly to the preferred 18” drivers, but allow much more input power before excursion is reached.
Ever hear anything from Oliver?
Cheers, all!
File Type: jpg B4A25192-7F22-4F11-9030-93F2156E0047.jpg (959.7 KB, 114 views)
File Type: jpg BEF2164E-C056-4CFE-8EAA-B190FFFE123D.jpg (95.4 KB, 122 views)
Last edited by CRESCENDO; 22nd October 2018 at 01:35 AM. Reason: Added info regarding brace mod
Old 24th October 2018, 08:59 AM   #995
hi justin
i don't know what happend to oliver,i'm sort of worried too.
the driver sims best is the 21DS115-4ohm for the FT30.
it has a litle bump on 60 hz of 1 db.
it wil need a slight change in the cone correction,and the speaker baffle
could point me to olivers sub youre reffering to?
to bad youre on the other side of the pond,where i could make the pannels on my router.
grt erik
. hr driver db
C/E/X PA Flat to 30 (FT30) PA TH AwesomenessHide this!Advertise here!
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 20 30th May 2013 04:54 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
Vintage Peavey PA-120 Transistor PA amp ElectricMan Swap Meet 2 26th May 2010 06:22 PM
Nakamichi PA-7 and PA-5 amps Redwingnine Pass Labs 11 30th April 2010 10:27 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 08:54 PM
