THAM15 - a compact 15" tapped horn
Old 19th October 2019, 05:49 PM   #531
martinsson is offline martinsson  Sweden
Note that the shape of the resonator peak is somewhat less sharp, my suspision is that the intentionally generous volume of air in the resonator, or air load (mass) contributes to this shape, it might also stem from it being a secondary coupled load post summation, making it differentiate from the standard tapped horn impedance peak signature.
Either way, if going by the impedance peaks alone then yes, this is not a pure 6'th order system, schematicaly though one might reach other conclusions, it shows the resonator function as an addition to standard th approach, and it's impact is far from a narrow local one as it boosts the entire passband.
Old 19th October 2019, 06:02 PM   #532
Brian Steele is offline Brian Steele  Grenada
Originally Posted by Circlomanen View Post
I'm guessing that the The little impedance peak between 100 Hz and 200 Hz is above the usable passband? I've so, I'd call that 6th order.
I've attached the sim'd impedance response for an 8th order system with a bandwidth from 40 Hz to just above 200 Hz. The 4 peaks are very prominent.
www.diysubwoofers.org
Old 19th October 2019, 06:43 PM   #533
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
The lines are a bit blurred, but usually a tapped pipe/tapped horn is seen as 6th order quarter wave BP, and if you add a front resonator to a 6th order you get an 8th order.
Nothing in the link below says 8th order enclodure to me. BeautifuI build and great blog though! I see a split path 2 stepped TH. The enclosure is modeled as a 4 segment TH. I think you could call it a regular series tuned BP6 due to the straight flare segments.
Martinsson's Blog - ROAR15
Old 19th October 2019, 07:23 PM   #534
Circlomanen is offline Circlomanen  Sweden
No. It is at 147 Hz and within the passband, and it is very much part of shaping it. It is clearly an 8th order per your "impedance-peak x 2" definition. The large front resonator cross section might have a lower Q amd a wider bandwidth and thereby a lower impedance peak then a comparable Helmholtz resonator.
We live in a horizontal world, why use vertical topologies???
Old 19th October 2019, 07:38 PM   #535
Your 210 Hz "prominent" peak peaks at 24 Ohm.
The 147 Hz forth peak of the ROAR15 peaks at 22 Ohm.
I hope those measly 2 Ohms does not disqualify the ROAR from the glorious world of 8th order bandpass alignments...
Old 19th October 2019, 10:18 PM   #536
BP1Fanatic's Avatar
Based on your graph and Brian's graph, the ROAR15 looks like an 8th order enclosure.
I take it that the 4th segment of 71.60cm creates the 8th order?
Old 20th October 2019, 09:24 AM   #537
ROAR15 compared with the tapped pipe section without the front resonator.
As is easily seen in the impedance graph, the front resonator adds another impedance peak (the third one). The large front resonator has a quite low Q and very wide bandwidth (as seen in the spl comparison) and hence the impedance peak has a quite low Q.
Yes. If the step up in cross section area is large enough and the section is long enough, then it acts as a separate resonator creating an 8th order.
Old 20th October 2019, 11:20 PM   #538
BP1Fanatic's Avatar
How come you don't have 4 parabolic segments in the model?
Old 21st October 2019, 06:34 AM   #539
rnbmccain is offline rnbmccain
Default T18
Originally Posted by martinsson View Post
Hello Johan
If i do the math on the dims only i arraive at your 187dm3 on the external dimensions, so far so good, and the S4 value tells me that the internal width is 464mm also a check, and the lengths L12,L23 & L34 are all correct in the sim.
My only naggin doubt is that the expansion may not be corretly simulated as the front chamber takes a step up in volume that is not shown in the system volume calculations.
Since this is a linear expansion (apart from the last step mentioned above) there maight be a deviation in there somewhere, the material part of the volume should be about 50dm3 (approx 12x24x0.18dm).
The differance between the volumes 187-173 = 14dm3 (given that the 173dm3 sim figure is correct) does not account for the material only, there is still a diff of approx 50-14 = 36dm3 left somwhere.
Now 36dm3 is not to be taken lightly, this is a significant amount of volume, a part of which can depend on the linear simulation of a non linear expansion, and the bends has been approximated, this maty also contribute, the sum of all this may give us the difference you describe.
Where and how these deviations are and lokk like, aswell as how great a apart they play remains to be figured out.
I will not change the design to fit the simulation, the simulations however may need another go to figure out exactly how this design simulates in detail, but the real world result is still, and has allways been, a very good one, the comments i have recieved sofar from users has been very positive.
Thanks for bringing this to my attention, I will as soon as possible try to iron this out, meanwhile me advice to all that are thinking about building this box is still "go for it", it works wery well, despite the suspected simulation errors.
If anyone out there wants to lend a helping hand in figuring this out and perhaps speed thing up please do so and let us know of your findings, i would be very grateful for any help i can get.
Best regards // Anders Martinsson
I like it! Can you give me some dims on an EV T18 scaled-down for a 12 inch Dayton pa310 driver!!!!!!!!!????????
Old 21st October 2019, 07:55 AM   #540
Because there is no difference with straight non expanding sections.
THAM15 - a compact 15" tapped hornHide this!Advertise here!
15" tapped horn with RCF wood1y Subwoofers 143 22nd April 2017 02:36 PM
Infinity BETA 15" sutable for a tapped horn? Jimjim Subwoofers 13 13th September 2010 03:05 AM
P.O.C. #2 - Compact Tapped Horn Brian Steele Subwoofers 17 18th September 2009 09:27 PM
Compact 15" sub - BMS or Precision Devices? DIAR Subwoofers 7 4th January 2007 05:06 PM
Copyright ©1999-2019 diyAudio
