Hornresp
Hornresp
Old 11th February 2019, 06:12 AM   #9171
David McBean is offline David McBean  Australia
Originally Posted by the lorn teat flag View Post
but when having a front loaded horn with a rear vented chamber it's not possible to put filling.
Hi Florent,
Model the front loaded horn with rear vented chamber as a compound horn. Filling material can then be added to the chamber (segment 1) and/or port tube (segment 3) as shown in the attachment. The horn itself will be limited to a single Con, Exp or Par flare.
Kind regards,
David
www.hornresp.net
Old 11th February 2019, 06:20 AM   #9172
Originally Posted by GM View Post
If it's in the HELP files I missed it.
www.hornresp.net
Old 11th February 2019, 07:50 AM   #9173
Originally Posted by NEO Dan View Post
It might be the Lossy LE in the wizard, it appears the default on state of Lossy Le is retained by the Baseline no matter what, it also takes some flipping of "switches" to turn off Lossy LE but ultimately the radio button is checked when the Lossy LE is off.
It's 180 degrees out of phase
Hi Dan,
If the lossy inductance option has been specified on the input parameters window (ie. Le label is red), then when the Loudspeaker Wizard is opened the 'Lossy Le' checkbox is shown ticked and the results take lossy inductance into account.
The Loudspeaker Wizard initial baseline does not take lossy inductance into account even if the option has been selected on the input parameters window. This may be changed in the next update.
Removing the Loudspeaker Wizard 'Lossy Le' checkbox tick calculates results without taking lossy inductance into account. The initial baseline is not affected either way by the 'Lossy Le' checkbox status.
I don't follow what you mean by "It's 180 degrees out of phase". More information would be appreciated.
Kind regards,
David
www.hornresp.net
Old 11th February 2019, 08:56 AM   #9174
GM is offline GM  United States
GM's Avatar
Thanks! I only searched 'S1'.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th February 2019, 09:58 AM   #9175
freddi is offline freddi  United States
freddi's Avatar
Hornresp
BIG thanks GM - saw the glaring change to red - but didn't think to click on it - what wonders might option allow ? ?
Old 11th February 2019, 10:26 AM   #9176
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
Hornresp
I know enabling Le is for better measure high BL drivers but i did not expect Le would have such high impact on the xmax. I also wonder what frequencies the Le is applied too is this full scale or just one or two ranges.
Here is an example of high xmax Le off/on on the POC4 2.83v 8 Ohm:
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 11th February 2019, 11:07 AM   #9177
freddi's Avatar
Hornresp
Hi David - that stepped allowance is really cool !
Old 11th February 2019, 12:38 PM   #9178
papasteack is offline papasteack  France
+1.
Originally Posted by David McBean View Post
Incidentally, once I clear all the bugs, I want to get back to further investigating the possibility of modifying the Loudspeaker Wizard to accept stepped cylindrical horn segments only. I think that this should be a lot easier to do than having to also allow for Con, Exp and Par flare stepped segments.
David, if you manage it, do you think stuffing feature should be working in this case ?
My BP8 simed as stepped segment TH bellow. Vent sizes were decided with BP8 wizard vent velocity screens. Active filtering is just a low pass at 5hz and a -7db eq @6hz, as over-excursion protection. It seems really doable. Filtering of the 53cm long vent spike @350hz seems optimistic beeing so near the mouth.
Old 11th February 2019, 08:06 PM   #9179
Josh Ricci is offline Josh Ricci  United States
Attachment 735602
It affects ALL drivers to some aspect or another. Some are much worse than others. It also has effects on ALL aspects of performance over the entire frequency range of operation. Driver excursion included.
Old 12th February 2019, 06:55 AM   #9180
The lossy inductance empirical model was originally developed by 'just a guy' using driver performance data provided mainly by Josh. The model reduces the value of Bl used in the Hornresp calculations, based on the specified values of Le and Re. With the Lossy Le option selected, the adjusted Bl value used by the program can be seen in the status bar panel at the bottom of the input parameters window when the mouse pointer is moved over the Bl input box, as shown in the attachment.
www.hornresp.net
HornrespHide this!Advertise here!
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2019 diyAudio
