Hornresp
Hornresp
Old 16th October 2018, 02:41 PM   #8731
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by NEO Dan View Post
This is a typical result when one goes into something with the mindset of making something happen rather than learning what the possibilities are.
Excellent statement!
Old 16th October 2018, 03:15 PM   #8732
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Dan hard to argue when you make sense.
Mark
www.kravchenko-audio.com
Old 17th October 2018, 06:21 AM   #8733
GM is offline GM  United States
GM's Avatar
Originally Posted by David McBean View Post
Word has a Find feature :-).
Greets!
Thanks for reminding me as I know you posted it ages ago when I had issues with using it, but haven't had OFFICE available for years now and only remembered I could change the extension to use in WordPad.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th October 2018, 06:26 AM   #8734
GM's Avatar
Originally Posted by Zero D View Post
Yes, good idea Then people could convert it to a PDF as well
Good to know, thanks! The laptop came with Foxit, but apparently I have to ante up for an upgrade to create PDFs with it.
GM
Old 17th October 2018, 07:50 AM   #8735
David McBean is offline David McBean  Australia
WordPad also has a Find feature :-).
www.hornresp.net
Old 17th October 2018, 03:44 PM   #8736
GM's Avatar
Thanks! Shows how much attention I pay to toolbars! Since it's a 'stripped down' WORD doc, just assumed it didn't have it, like Foxit appears to have a functioning 'create' feature till I tried to use it.
GM
Old 17th October 2018, 11:04 PM   #8737
Zero D is offline Zero D  United Kingdom
GM
I use foxit as well. I haven't installed the extra to print PDF's though. Instead i use the option in the very good & Free LibreOffice
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 18th October 2018, 09:01 AM   #8738
Originally Posted by LORDSANSUI View Post
it would be interesting also to deactivate the button save while the user don't change any value, so it's a visual feedback to remember the user that nothing was changed, so the button would be active only if one ore more parameter were changed.
This refinement will be in the next release.
www.hornresp.net
Old 18th October 2018, 09:22 AM   #8739
SamAnytime is offline SamAnytime  India
GM
If you have MSWord, you can save as PDF.
Old 19th October 2018, 09:10 AM   #8740
Sabbelbacke is offline Sabbelbacke  Germany
simply install a PDF-Creator, which works as a printer device... This way you can make PDFs by simply printing from any windows application... More recent Windows versions have a Microsoft ODF Printer installed. Or try openoffice / libreoffice - which has build in PDF Export.
The times where you have to spend a lot of money buying microsoft acrobat to get a PDF are over for at least a decade, its very simple nowadays.
www.hornresp.net
HornrespHide this!Advertise here!
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2019 diyAudio
