Hornresp
Hornresp
Thread Tools
Old 6th September 2021, 06:27 AM   #12381
David McBean is offline David McBean  Australia
Originally Posted by David McBean View Post
The horn would then have the general form shown in Attachment 2 (not to scale).
Just to clarify - as far as the model used in the actual simulation is concerned, to be theoretically correct, segment 4 should have an exponential flare not a conical one.
I suspect that it won't make much practical difference to the calculated results either way, though.
www.hornresp.net
Old 6th September 2021, 06:40 AM   #12382
Originally Posted by mwmkravchenko View Post
To mimmic the bifuricated design I would design a horn with the appropriate mouth area of one half of the enclosure. I modeled them together using the tools button then multiple speakers. There will be a difference in impedance and therefore SPL due to the choices of series or parallel for the driver impedance.
Hi Mark,
With a bifurcated design, to avoid the differences you mention simply double the cross-sectional areas of one half, and simulate as a single speaker.
Kind regards,
David
www.hornresp.net
Old 6th September 2021, 04:44 PM   #12383
mwmkravchenko is offline mwmkravchenko  Canada
mwmkravchenko's Avatar
That is a way that I have done also David.
There are many paths to simulation using Hornresp. It's what makes it such a versatile program.
And such an invaluable program!
Mark
www.kravchenko-audio.com
Old 7th September 2021, 03:05 PM   #12384
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Looks like all the segments should be parabolic.
Ol' Skool Hip Hop Basshead = Car Audio: Coustic Power Logic HT-612 in a BP4. Home Audio: Kicker 08S15L74 in a T-TQWT.
Old 8th September 2021, 09:20 AM   #12385
Because segments 1 and 2 have been specified as very short cylinders, the flares chosen for those segments have no meaning, and are therefore disregarded when calculating the results.
The flare of segment 3 is ill-defined, it is neither one thing or the other. Take your pick - your guess is as good as mine :-).
Because only segment 4 is available to specify the remainder of the system, it needs to be exponential to reflect the overall cross-sectional area expansion rate of the horn.
However:
If three segments were available to specify the remainder of the system, then strictly speaking the first and third segments as shown in Attachment 1 should be parabolic. The flare of the middle segment shown in Attachment 1 is ill-defined (similar to segment 3 mentioned above).
Even if parabolic segments were used, the overall flare expansion rate would remain effectively exponential, as can be seen by comparing the profiles of Attachments 2 and 3.
www.hornresp.net
Old 8th September 2021, 09:53 AM   #12386
elmans is offline elmans
Hello,
I apologize for the very basic questions, hopefully they can be answered quickly (I honestly cannot read 1300 pages before I post, I did read a good bunch of the wiki and the hornresp help).
I am trying to model some simple (Vifantastich (see post #155) with TC9FD18) and not so simple (FrugelHorn with FE126En).
I take the driver parameters from loudspeakerdatabase.com, which may be a first isue as I don't have the same parameters as the references on the respective threads.
Also there must be other significant errors in my sims, because the results are way off (so much I don't dare to post them) :
Would someone be so kind to post the correct input parameters for either or both loudspeakers ?
Thanks lots in advance
Old 8th September 2021, 06:40 PM   #12387
freddi is offline freddi  United States
freddi's Avatar
Hornresp
Hi David
Is the attached sim something which "should" be a straight forwards build? I don't know if its feasible much less straightforwards
Best wishes,
Freddy
File Type: jpg IS THIS THROAT VENTED SIM FEASIBLE.jpg (431.2 KB, 67 views)
Old 8th September 2021, 07:02 PM   #12388
freddi's Avatar
Hornresp
Hi elmans - here's a mass loaded version which might be of help as its response was documented
Flat Wall Mount Stereo MLTL using TC9FD's (2)
Old 8th September 2021, 11:29 PM   #12389
BP1Fanatic's Avatar
However:
If there are parallel walls (top & bottom or left & right
panels) from the throat to the mouth of a horn, then all the segments are parabolic.
Old 8th September 2021, 11:37 PM   #12390
BP1Fanatic's Avatar
B an C are parabolic horns.
File Type: jpg Screenshot_20210908-183526_Samsung Internet.jpg (239.7 KB, 35 views)
HornrespHide this!Advertise here!
Thread Tools
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
