Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11821 | |
Switching to Cyl becomes problematic when editing an existing record, which tends to be what most users do. To illustrate, assume that for the first segment S1 = 100, S2 = 2000 and L12 (Exp) = 100. If Exp is switched to Cyl, does S1 change to 2000 or does S2 change to 100? Rather than setting a rule I prefer to leave it up to the user to decide which way to go, depending upon the circumstances (ie. whether the segments are stepped, and if not, what area value is required for the throat of segment 2). Besides, there is no real requirement to have a Cyl option as Con, Exp and Par have all been intentionally coded to support S1 = S2.
www.hornresp.net |
#11822 | |
Consider yourself lucky if the Paraflex option is ultimately added (by no means a certainty at this early stage).
www.hornresp.net Last edited by David McBean; Yesterday at 12:05 PM. |
#11823 | |
![]() I was thinking about the "throat chamber" conundrum in the putative PA system model and was wondering if the existing "Driver front Volume" calculator be used to define this? |
#11824 |
Also trying to work out if SD Vas etc can get us somewhere close to predicting the vtc of a driver flush mounted perpendicular to the path a horn....?
#11825 | ||
Is it still worth trying to implement the Paraflex model if driver front volume is not taken into account, bearing in mind that the rear volume occupied by the chassis and magnet assembly is currently disregarded in most cases?
www.hornresp.net Last edited by David McBean; Today at 08:32 AM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Some questions about hornresp | brsanko | Full Range | 7 | 3rd December 2018 10:04 AM |
Hornresp Class | FlipC | Subwoofers | 11 | 4th June 2016 07:33 AM |
Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 04:56 PM |
New To Site? | Need Help? |
