Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11001 |
Hi
I tried modelling the attached TQWT but the output looks questionable compared to other sims I have seen leading me to think I've entered wrong areas at different parts of the line. Can the good folk spot where I may have gone wrong? Please let me know if this is a question for a different forum of course. I am uncertain of the inductance value of the Triangle T17FL2 driver which may be an issue but the value of .18 mH was on a french catalogue of T/S parameters for the unit. Seems low though. |
#11002 |
Woodoo, look at the Vas. Kinda large it seems.
Try a 600-650cm2 CSA Offset driver TL at a 55-65cm Length to driver and 120cm from there to exit? Last edited by Booger weldz; 18th August 2020 at 10:38 AM. |
#11003 |
thanks Booger, will have a look. the Vas of the driver is rated at 40L. it does seem high.
#11004 |
This may help... DIY Audio Projects Forum • "Hazard" wide band speaker load
#11005 |
Thanks, same guy's speaker. Was interested in how to model the TQWT which I am having trouble getting a sensible output. I see a figure for the inductance though which I wasnt sure about.
#11006 | |
My HR inputs are close to yours except using the base specs and yes, without factoring in driver/vent delay [Chamber/Path] to the listening position [Lp], stuffing impact [Filling] makes for a pretty pathetic looking sim. That said, this one is barely > Vas, so at minimum a bit small and more so if significant series resistance [Rg] and/or stuffing to smooth it out isn't factored in. If seated ear height is much different than ~31", consider making the pipe based on yours and use the Wizard to try different net volumes [Vb]. For instance, a T/S max flat alignment is ~100.28 L/44.6 Hz Fb, so ~2.5x larger, tuned slightly lower and depending on the room's acoustics, could be tuned as low as ~0.707x Fs = ~41 Hz. Some have pushed drivers [much] lower, but power response 'drops like a stone' [excursion increases 4x/octave], so 'caveat emptor' applies big time with a tiny Xmax driver. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#11007 |
@GM and others. Thanks for your analysis. Will play further based on your recommendations.
#11008 | |
GM
#11009 |
~T/S max flat sim based on my ~39" ear height.........
GM
#11010 |
Where is the official download site for hornresp?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Some questions about hornresp | brsanko | Full Range | 7 | 3rd December 2018 10:04 AM |
Hornresp Class | FlipC | Subwoofers | 11 | 4th June 2016 07:33 AM |
Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 04:56 PM |
New To Site? | Need Help? |
