Hornresp
Hornresp
Old 18th November 2019, 04:15 AM   #10201
David McBean is offline David McBean  Australia
Thanks for the feedback everyone.
"All's well that ends well"... :-).
www.hornresp.net
Old 18th November 2019, 12:48 PM   #10202
pelanj is offline pelanj  Czech Republic
Finally, my book from Lean Business arrived. I yet have to open it, but it weights something like 10 kilos
Old 21st November 2019, 07:05 AM   #10203
Default Hornresp Update 5050-191121
Hi Everyone,
BUG FIX 1
The Lpt label was shown as Lp Lpt in the Loudspeaker Wizard when it should have been shown simply as Lpt. This has now been fixed. Attachments 1 (before) and 2 (after) refer.
BUG FIX 2
The ME1 and ME2 chamber schematic diagrams in the Multiple Entry Horn wizard were correct but the main schematic diagrams were not. These have now been fixed. Attachments 3 (before) and 4 (after) refer.
Kind regards,
David
www.hornresp.net
Old 22nd November 2019, 02:54 AM   #10204
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Hornresp
Upgraded over the course of the morning.
My thanks to the rapid response one man bug team
Mark
www.kravchenko-audio.com
Old 22nd November 2019, 07:56 AM   #10205
Just call me Spider-Man :-).
www.hornresp.net
Old 22nd November 2019, 03:44 PM   #10206
mark100 is offline mark100  United States
Bug-man extraordinaire
and thanks for the clarifying work regarding Max SPL tool ..
Quick question about excursion...
Since we input RMS voltage, I assume hornresp uses the peak voltage of a sine wave (+3dB) for determining excursion? (and not some other crest factor)
Still working on frequency dependent limiting for prosound...
...just double checking... thx
Old 22nd November 2019, 11:39 PM   #10207
b_force is offline b_force  Europe
Maybe some people can help me out here.
I used to run Hornresp just totally fine a while back under Manjaro Linux Wine with the LC_ALL='C' command.
Since a few weeks I installed Manjaro once again with the newest Wine version and I get an "run-time error '52' " when starting up Hornresp.
Any other people that run into this issue (or at least can replicate) ?
Old 23rd November 2019, 01:48 AM   #10208
citizen sc is offline citizen sc
Hi Guys
I'm having a bit of trouble getting my hornresp frequency response graph to match reality closely enough to make design decisions on a project I'm starting. I am trying to simulate a block of 4 punishers sitting on the ground, not next to a wall. Punisher plan is here Punisher Horn MKII
I know from measuring my system with smarrt multiple times that the punishers roll-off at about 40hz. The sim is showing the roll-off at closer to 55hz.
I have tried simming the punishers as both OD and ND but it makes little difference.
You can see all my input parameters and graphs here Help developing Hornresp parameters from plan - Speakerplans.com Forums
I hope linking to my post in another forum is not an issue.
Old 23rd November 2019, 07:02 AM   #10209
Hi mark100,
The maximum displacement of the driver diaphragm from its mean position is given by:
Dd = Sqrt(2) * Vd / (2 * Pi * f)
Where Vd is the rms velocity of the driver diaphragm at frequency f, and for rms input voltage Eg.
Kind regards,
David
www.hornresp.net
Old 23rd November 2019, 07:10 AM   #10210
Hi b_force,
Just to clarify - is the version of Hornresp that no longer works, the same as the one you were successfully using before you updated Wine?
Kind regards,
David
www.hornresp.net
HornrespHide this!Advertise here!
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Copyright ©1999-2019 diyAudio
