Hornresp
Hornresp
Hornresp Please consider donating to help us continue to serve you.
Old 16th November 2019, 08:11 PM   #10191
Andre Vergison is offline Andre Vergison  Belgium
You may find old copies of Setup.exe in your downloads folder and try them.
Old 16th November 2019, 08:33 PM   #10192
musgofasa is offline musgofasa  United States
Send a message via Yahoo to musgofasa
Thanks for looking into it guys. I just got back to my PC with the thought of getting the .dat file uploaded but I see it's already been done. Much appreciated. I was going to upload a copy of the last rev file but realized I recently cleaned up my PC and removed it. Funny thing is I think I had the last 5 or 6 rev files still on my machine! I'm not even sure why I would have deleted those.
Old 17th November 2019, 03:24 AM   #10193
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by David McBean View Post
Hi Everyone,
It seems that there is an issue running the latest release of Hornresp on Windows 10.
Unfortunately because I do not have Windows 10 myself and cannot see the problem, I will require more feedback if the cause is to identified.
Could someone experiencing the problem please close Hornresp, delete or archive their existing Hornresp.dat file, restart Hornresp to create a new Hornresp.dat file containing just the default record, and see if the problem is still exists. If it does, could you please post a copy of your new Hornresp.dat file as an attachment.
Kind regards,
David
I was over my father's house today and downloaded HR onto his laptop. I played around in HR until I noticed he needed to update Windows 10. I updated windows 10 and HR worked fine afterwards. I'm about to check the HR dat file on my laptop.
Old 17th November 2019, 05:09 AM   #10194
David McBean is offline David McBean  Australia
Default Hornresp Update 5050-191117
Hi Everyone,
BUG FIX
The 'type mismatch' fatal run-time error problem first reported in Post #10178 has now hopefully been fixed. Could someone who experienced the problem please confirm that everything is now working correctly.
My thanks to Andre for his help in isolating the cause of the problem.
Kind regards,
David
www.hornresp.net
Old 17th November 2019, 05:26 AM   #10195
It turns out that the problem had nothing to do with what Windows operating system was being used. I was able to see the issue for myself using Windows 7 when I tried to run the data file Andre posted. This enabled me to quickly identify the cause. The reason I did not have the problem originally is because it only occurred with records of a certain "age". Just by chance, none of the records in my own Hornresp.dat file fell into that age category.
www.hornresp.net
Old 17th November 2019, 12:06 PM   #10196
prazza1 is offline prazza1  France
Hi David, it is ok now. Many thanks !!
Old 17th November 2019, 12:40 PM   #10197
Originally Posted by prazza1 View Post
it is ok now.
Hi prazza1,
Excellent :-).
Many thanks for letting me know.
Kind regards,
David
www.hornresp.net
Old 17th November 2019, 02:53 PM   #10198
grindstone is offline grindstone  United States
grindstone's Avatar
Many thanks for the bugfix, David -- all is well on wine 3.0 again
Old 17th November 2019, 03:49 PM   #10199
Working fine now, thanks for this fast fix!
FYI I was using Windows 7 as well. Nothing to do with OS version indeed.
Andre
Old 17th November 2019, 09:33 PM   #10200
BP1Fanatic's Avatar
Thank you David! I just downloaded the latest version and it's working fine.
HornrespHide this!Advertise here!
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
