Hornresp
Hornresp
Hornresp Please consider donating to help us continue to serve you.
Old 15th November 2019, 08:40 PM   #10181
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
Hornresp
Originally Posted by 1hiep0 View Post
Hi Cowanaudio, would ports noise increase? Thanks,
As long as your ports are sufficient area and not ridiculous in proportion you should be fine. Four round ports of sufficient size to keep velicity down works fine.
Don't Procrastinate....Just Do It!
Old 15th November 2019, 10:53 PM   #10182
grindstone is offline grindstone  United States
grindstone's Avatar
Originally Posted by musgofasa View Post
Having the same type mismatch error in regular windows 10. Can't click next or previous but everything else seems to work. Any ideas?
Going back to the 191023 rev for now works for me until there's more time to look harder at this (and hopefully provide something useful for David to use).
Old 16th November 2019, 03:36 AM   #10183
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
I'm getting the same error. I just updated Windows 10. I updated HR to version 50.50 and get this. Wow, I just noticed some of the input field names are missing!
Old 16th November 2019, 07:50 AM   #10184
David McBean is offline David McBean  Australia
Default Type Mismatch Run-Time Error
Hi Everyone,
It seems that there is an issue running the latest release of Hornresp on Windows 10.
Unfortunately because I do not have Windows 10 myself and cannot see the problem, I will require more feedback if the cause is to identified.
Could someone experiencing the problem please close Hornresp, delete or archive their existing Hornresp.dat file, restart Hornresp to create a new Hornresp.dat file containing just the default record, and see if the problem is still exists. If it does, could you please post a copy of your new Hornresp.dat file as an attachment.
Kind regards,
David
www.hornresp.net
Old 16th November 2019, 08:09 AM   #10185
Originally Posted by whgeiger View Post
How About a Sensitivity Analysis Tool that explores system sensitivity to driver parameter tolerances (variation).
If you are looking for a "parametric sweep" type tool, then that's not going to happen. I'm afraid you will just have to make do with selecting the Driver input option in the Loudspeaker Wizard, and adjusting the slider values to see what happens to the results :-).
www.hornresp.net
Old 16th November 2019, 10:39 AM   #10186
Andre Vergison is offline Andre Vergison  Belgium
Default Hornresp 50.50 crashing
Hello David,
Upgrading from 50.30 to latest 50.50 introduced an error 13 (type mismatch) whenever loading my usual data file followed by moving to the 'next' record. Looking at the file (UltraEdit) I see that the first record is the default set, and I attached a cut out of the second, probably faulty, record (hope it is right).
Why would it crash where 50.30 (and older versions) did not?
I could email you the whole file if you'd like to.
Thanks,
Andre
Old 16th November 2019, 11:10 AM   #10187
I think I'd better post the entire file, here you go. (adding extension .txt)
I see that after opening a datafile Hornresp modifies the modification date but does not modify the file.
I just ran 50.30 again and 50.30 finds this file okay (all records can be browsed). But 50.50 crashes on the 'next' to the second record.
The file counts 22020 bytes.
Thanks,
Andre
Old 16th November 2019, 11:16 AM   #10188
prazza1 is offline prazza1  France
I have same problem with the last version, but I also lost the previous version. In the meantime, please how to get the 50.30 version from your site ?
Old 16th November 2019, 12:13 PM   #10189
Hi Andre,
Many thanks for posting the file - it has enabled me to quickly track down the statement in the source code that is causing the problem.
I will try to release and update tomorrow, which will hopefully fix things.
Thanks again for your invaluable help!
Kind regards,
David
www.hornresp.net
Old 16th November 2019, 12:18 PM   #10190
Sorry, I don't retain copies of earlier versions.
www.hornresp.net
HornrespHide this!Advertise here!
Some questions about hornresp brsanko Full Range 7 3rd December 2018 10:04 AM
Hornresp Class FlipC Subwoofers 11 4th June 2016 07:33 AM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
