Post your Solid State pics here.
Thread Tools
Old 13th January 2021, 09:03 AM   #6971
Mrcloc is offline Mrcloc  South Africa
I built two small speakers for my desk, and naturally they need an amplifier. So I've put together two small amplifiers mostly from parts I had lying around. Should do about 40W into each, which is perfect.
Old 16th January 2021, 06:02 PM   #6972
vitalica is offline vitalica  Europe
vitalica's Avatar
I am very happy that I finally managed to finish this project with TSSA V4 amplifier. I made a dual mono variant, with 2x52VAC / 1000VA transformer, with RIFA PEH169 capacitors. Very detailed, huge dynamics, fast bass and fist, I just love it.
Old 16th January 2021, 06:08 PM   #6973
fotios is offline fotios  Greece
fotios's Avatar
Great job vitalica, very nice enclosures.
Best Regards FOTIS ANAGNOSTOU
Old 16th January 2021, 06:26 PM   #6974
venar is offline venar  Greece
venar's Avatar
1/3 of the heatsinks are for decorative reasons!
my way or no way!
www.supersonics.gr
Old 16th January 2021, 07:02 PM   #6975
zman01 is online now zman01  Bangladesh
Well done vitalica!
Old 16th January 2021, 07:50 PM   #6976
vitalica's Avatar
Default case
Are you sure ? Did you ask how much total bias it has?
Old 17th January 2021, 07:54 AM   #6977
fotios's Avatar
I agree, all heatsinks look very well joined. I suppose you have applied thermal conductive paste on all join surfaces
Old 17th January 2021, 08:25 AM   #6978
venar's Avatar
As i can see the output devices are bolt to the 2/3 of the heatsinks as active cooling!
So no matter how much total bias it has( the more bias the worst thermal resistant to the third party of the sink even thermal paste applied) temperature measurements will tell you the truth
Well build box for the show not for the go!
You need to redesign your board if you want to get the most from your <high bias> amp with your chosen box
my way or no way!
www.supersonics.gr
Old 17th January 2021, 09:11 AM   #6979
AudioSan is offline AudioSan  Norway
First of. That is not active cooling. It is the definition of passive cooling.
And you are wrong about the third heatsink only being for show. It will ofcourse be less effective. But is will still have effect. So will the top, botom, rear and front panel too.
Old 17th January 2021, 09:31 AM   #6980
venar's Avatar
Of course it's a passive cooling!
It's <active thermal path > for the output devices that are bolt on them!!!
No effective at all!heat spreading is just bad
my way or no way!
www.supersonics.gr
Post your Solid State pics here.Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
