Post your Solid State pics here.
Thread Tools
Old 18th September 2020, 04:14 AM   #6871
Summitp is offline Summitp  United States
Wow fab! That looks fantastic! It is making me thing about building a mini amp for the kitchen. Maybe I will look into one of your ussa pcbs.
My adventure in diy amps started off with the honey badger, I already posted pics of the Denon badger, that was my second, and went very smoothly. My first badger struggled with one board. I did resolve the issue, and completed the rest of the project steps tonight. I like to recycle stuff because I am a cheapskate and a hoarder, and I had a nice t3 tape player that needed belts. 30 minutes into that job and I was like, "$&#& that!" And decided the kids could take it apart and play with it. But the meters were cool and looked nice, and worked. So I pulled them and set them aside. I refinished the arcam faceplate, filled and sanded all the holes, and painted it a very dark metallic grey. The meters were a PERFECT fit. Also got the power led working. Now all project ideas I was hoping for on this one are done. Meters work, thd over light works, backlights set up, and closed up, back in the lineup. And yes, I did clean up the wiring, birds nest is gone, everything is nice and short and properly stowed away. 🙂
Old 18th September 2020, 04:46 PM   #6872
fab is offline fab  Canada
fab's Avatar
Thanks Summitp!
Note that actual production USSA3 pcb are too tall for this small chassis. My prototype USSA3 board was using a reworked F5 pcb...
I wanted to demonstrate that even an all-in-one class A amp with moderate power can be a small size too where space is an issue or for easy transport.
You have done quite a nice job on your recycled amp too.
Fab
My stuff USSA, FSSA, USSPA: https://fabaudio.online
Old 21st September 2020, 10:25 AM   #6873
stretchneck is offline stretchneck  United Kingdom
Originally Posted by fab View Post
This is a mini push pull class A amplifier of about 9W rms / 8 ohms and including a musical server consisting of raspberry pi with a DAC and 2 x USB keys of 256GB to store more than 900 CDs in flac format. It also has an additional USB port for external USB key (as shown) to easily add music....Speaker DC protection circuit also included. The chassis is only 260mm x 300mm x 70mm and internally 160mm width). So it is portable and playable even where no internet connection is available since music is stored locally and the pi provides a hot spot So I can select music from my phone or iPad. The only thing missing is some small speakers...
Fab
Lovely work Fab - you should post more details. I am also thinking about using USSA at very low wattage when matched with some smaller super efficient speakers for nearfield listening.
Old 21st September 2020, 04:40 PM   #6874
fab's Avatar
Hi stretchneck
Thanks!
This is a pictures thread....so I try to avoid putting too much technical details...
I can post a dedicated thread - if need be - but it is mainly the small size of this integrated Class A all-in-one amp that is the main feature.
If you have specific questions you can send me messages too. Finally if you can read French or use a translator see this other forum thread : Mini Ampli Class A avec serveur musical
Fab
Old 24th September 2020, 01:34 AM   #6875
wtnh is offline wtnh  United States
wtnh's Avatar
Fab - simply lovely! Nothing more need be said.
Old 24th September 2020, 05:10 AM   #6876
fuego is offline fuego
Default BA1200
YouTube
Old 24th September 2020, 08:32 AM   #6877
diyralf is offline diyralf
diyralf's Avatar
Nice project name and a nice pot scale. Where did you buy the heat sinks?
Old 25th September 2020, 03:20 AM   #6878
Ebay @ Audiophonics DIY
Old 25th September 2020, 09:07 AM   #6879
diyralf's Avatar
Thanks!
Old 27th September 2020, 07:45 PM   #6880
routhun is offline routhun  United States
Very nice build. Very good. Congratulations on your new excellent Amp
Originally Posted by fuego View Post
routhun
Post your Solid State pics here.Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
