Post your Solid State pics here.
Old 26th December 2017, 04:58 PM   #5521
chientechnical is offline chientechnical  Viet Nam
Originally Posted by kct View Post
Nice.
Do you have by chance any datasheet and perhaps a source for the (brown) resistors you used ?
They are Kamaya Carbon Composite. I buy them from Mouser.
Old 28th December 2017, 05:46 PM   #5522
ZoSoNCSU is offline ZoSoNCSU  United States
Originally Posted by east electronics View Post
Placing a question about the large capacitors only, means that you dont have your way around these amplifiers.....
I asked only about the "large capacitors" because I already knew the others needed to replaced. It's funny what people will read into. Thanks for the effort though!
Come take a look at the new HL Catalog Database:
https://hallmanlabs.com/catalogs/
Old 29th December 2017, 11:46 PM   #5523
Drdorkmeister is offline Drdorkmeister  United States
Default LJM MX50SE
Threw this inside an old NAD case. Using a subwoofer transformer and upgraded the caps and output transistors from the kit. Going to install speaker protect and a tube buffer later. Getting 55 WPC RMS and pretty clean nice sound.
Old 30th December 2017, 01:54 AM   #5524
kct is offline kct  Canada
kct's Avatar
^^^ nice.
Old 30th December 2017, 10:26 PM   #5525
alex mm is offline alex mm  Romania
alex mm's Avatar
GainWire 3.1 and power supply . Happy new year !
Old 30th December 2017, 10:44 PM   #5526
kct's Avatar
^^^ nice, another clean build.
Old 31st December 2017, 05:30 AM   #5527
hadihf is offline hadihf  Pakistan
Default paX build
Finally finished Jan Didden's Error Correction Amplifier. Very pleased with the sound. Great clarity and accurate sound stage.
Using a soft start with mains filter from Audio special no5. Its under the cap bank.
Farooq
Old 31st December 2017, 06:35 AM   #5528
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Very nicely done Farooq! I know the paX is not the easiest amp to build, what with the very unusual use of the AD844 in the error correction concept.
It took some time but the result is very nice, congrats!
Jan
Old 31st December 2017, 07:01 AM   #5529
Default paX build
Jan,
Thanks for your support while building this wonderful amplifier.
Best Regards
Farooq
Old 31st December 2017, 10:26 AM   #5530
dadod is offline dadod  Croatia
dadod's Avatar
Nice build. Alex is it working, did you listen to it?
I am a bit concern with thermal runaway of the output buffer, I suggest you to connect thermally in same way the buffer small transistors.
BR Damir
Post your Solid State pics here.Hide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
