Post your Solid State pics here.
Thread Tools
Old 15th December 2016, 12:34 AM   #5011
kct is offline kct  Canada
kct's Avatar
Originally Posted by tmyr View Post
..its all cnc machined from 6 and 2.5mm thick aluminum, 6mm Plexiglas and double sided fr4 . the specs are as for +/-40v rails class AB amp . those 20 smd fets equal to about 2 irfp250's . it is as big as a SSD though..
Pretty cool, I like the form factor.
Very nicely executed CNC work, very impressive.
Old 15th December 2016, 06:54 AM   #5012
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Juma's BF862-based SE Class A Preamp. Sounds wonderful.
Old 15th December 2016, 03:24 PM   #5013
Bigun is offline Bigun  Canada
Bigun's Avatar
Looks really nice. Good match with the shirt too
Looking good too 'X'
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th December 2016, 03:39 PM   #5014
yngvejos is offline yngvejos  Norway
yngvejos's Avatar
That looks awesome! Nice work.
Old 15th December 2016, 09:40 PM   #5015
rfj5106 is offline rfj5106  United States
Kaplaars. Superb construction. Please tell me about what looks like a ferrite torus for filtering AC in one of your photos?
Richard Jenkins
Old 17th December 2016, 03:14 AM   #5016
Got Foam?
xrk971's Avatar
This is cool looking.
Jeff Rowland amp.
Old 17th December 2016, 08:55 AM   #5017
Got Foam?
xrk971's Avatar
Default SE Class A Headamp using Ten BF862 JFETs
Just built this using my own hand etched boards and PowerPoint layout art. Design is by EUVL from this thread. Single rail supply is nice for portable application and I am using a step up booster (adjustable but set at 17v) to allow running from 5v cell phone charger. Bias current is about 50mA total. Drives my DT880-250's with ease.
BF862 Preamp
Nice sounding amp and another winner from EUVL.
Old 19th December 2016, 12:26 AM   #5018
Got Foam?
xrk971's Avatar
Finally, a boxed portable amp.
http://www.diyaudio.com/forums/headp...hout-heat.html
Old 19th December 2016, 12:50 AM   #5019
No 4 is offline No 4  United States
Jeff Rowland amp.
It is. Very organized, very symmetrical, every thing a DIYer attempts to achieve. How does it sound? Who knows. I most likely never will. How would those heat sinks perform in class a? Very curious.
This heat sink + F5 = blasphemy?
1pcs full Aluminum precision CNC processing power amplifier heatsink 320*90*60mm | eBay
Will.
Old 19th December 2016, 06:11 AM   #5020
Got Foam?
xrk971's Avatar
Those heatsinks look cool but awful performance wise. They don't follow engineering principles of maximizing surface area vs volume (you need some to conduct heat to the tip of the fin). Fins should not be thick like this - serves more as thermal mass than fin radiator.
Post your Solid State pics here.Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
