PGA2310 Digital Volume Control
Old 25th September 2019, 02:12 PM   #101
ginetto61 is offline ginetto61  Italy
Originally Posted by V8VHSLE View Post
And with 18 years of testing, does anyone have an opinion on the PGA2310 / PGA2311 remote controlled volume and input selectors that you can find on eBay? I'm just looking for an easy way to add remote volume control (and change inputs) that won't adversely affect sound quality.
i have ordered one ... it should arrive soon. I have seen some measurements in the web and they are nothing special, well below the potential of the chip itself.
The fact that high end manufacturers have adopted it for their preamps means that the potential for great sound is very real.
The part is very good ... but the actual implementation can be what makes the difference between a decent and a very good sound.
“Without music, life would be a mistake” ― Friedrich Nietzsche
Old 25th September 2019, 04:29 PM   #102
zgtc is offline zgtc  Europe
zgtc's Avatar
you have several threads here about this subject, either with pga2310 or similar:
Balanced Volume Controller / Line Stage
Building a complete Preamp with an Arduino, remote, volume and input control
My new preamp design: Arduino, 6 input selector, MDAC attenuator, IR etc
WM8816 digital volume control (WM STAMP)
Old 30th September 2019, 04:47 AM   #103
hi i can speak only for a unit made by weiliang and bought from eBay
after a while my unit has started sending sparks through the line
it is it because i get many noise hitting the case with a finger
i peeped inside it looks well built
i really do not know the origin of the noise maybe a qc issue or bad solder or fake chips?
i have another one coming hope it will be better
nice little unit but i cannot use it
Old 30th September 2019, 04:56 AM   #104
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by ginetto61 View Post
...PGA2310 i cannot see PSRR data in the chip datasheet ...
May be similar to PGA2311, below.
Are you planning to feed it bad power?
Old 30th September 2019, 05:09 AM   #105
hi thanks for the info
actually i was thinking to mod a cheap unit based on it
but i think i will try instead to put a remote control in a normal preamp
i need to control the volume with a remote
these parts are smd and impossible for me
replace the volume control should be less challenging i hope
Old 30th September 2019, 07:47 AM   #106
Sorry for my english ... i meant that i am experiencing electric shocks through the speakers very scaring. I disconnect all immediately.
I will check the markings on the chips asap ... however it looks exactly this one here below
i am thinking about extracting the bluetooth chip that i do not use at all ...
Old 12th May 2020, 09:20 PM   #107
djbone is offline djbone
I have one of the units made by Nobsound /Douk Audio available on Amazon and Ebay (UK). When it works, the sound quality is nothing short of sensational. *When* it works! After about 5 months I started losing one stereo channel, I switched inputs which temporarily resolved the issue, then the new input developed the same fault! Eventually, that input fails completely. Sometimes, after a few days, the input works normally again! A component overheating maybe?
Such a shame, as it's a unique piece of equipment, combining 3 RCA inputs, Bluetooth AND a remote control! Ideal to partner with vintage amplifiers.
Douk replaced the first one but have not responded to my enquiries about the second failed unit. If anyone has any ideas how to fix I'd be mightily grateful.
Old 4th June 2020, 09:39 AM   #108
Anyone have any thoughts on the issue I described? Or experience with an assembled PG2310/11 based unit from another supplier? Thanks in advance
Old 30th June 2020, 04:33 AM   #109
johnplayerson is offline johnplayerson  Canada
It would seem to me It is just the inputs....... so reflowing the solder connections on the rca inputs should fix the issue. I ordered on of these off Aliexpress. Still waiting as they seem to take long by the feedback... but feedback in general is quite good on these units.
There should not be much that can go wrong. There are so few parts that one should be able to fix any issue themselves just by changing them, as a project.
  Reply to this post
PGA2310 Digital Volume ControlHide this!Advertise here!
digital volume control aardvarkash10 Parts 12 2nd May 2016 07:13 PM
5.1 Volume control with PGA2310 rehanabid Chip Amps 35 7th September 2013 12:31 PM
Digital Volume Control day1118 Solid State 27 19th November 2008 07:42 PM
XBoSoZ + PGA2310 volume control JDeV Pass Labs 6 21st October 2004 08:30 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
