Soundcraftsmen 900X2
Old 11th July 2005, 08:11 PM   #11
still4given is offline still4given  United States
still4given's Avatar
First thing I would do is measure for DC on the outputs. I would also measure for AC on the filter caps. My first PCR-800 did that and all it needed was new filter caps. My second one had some drivers out on the power supply. I just swapped those out and it plays perfectly. Cost me something like $10.
Blessings, Terry
Old 11th July 2005, 09:56 PM   #12
oPossum is offline oPossum  United States
oPossum's Avatar
I have a ProPower 4 that did the same thing. Loud buzz, lights, and a horrible stink. One of the filter caps gave out and vented.
Remove the regulator board that sits on top of the caps and check for signs of venting or bulging.
It is a good idea to replace the SCRs and their drivers in addition to the bad caps. At least check them if you don't want to replace. A bad SCR will quickly destroy the caps.
Old 11th July 2005, 09:59 PM   #13
cygnusxi is offline cygnusxi  United States
Default Soundcraftsmen 450X2
I meant shorted.
Old 12th July 2005, 08:32 AM   #14
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Hello guys!, have you some Soundcraftsmen schematic?
Please, send it to me, i never constructed any circuit of this brand.
As i can remember, a genuine US Industrie, and a very respectable brand.
I will be happy to hear the sound produced, or, at least, inspect the schematic thopologie.
Thanks in advance.
nanabrother@yahoo.com
regards,
Carlos
Old 12th July 2005, 03:29 PM   #15
Thanks for the responses. What does SCR stand for?
No bulging on the caps, but there were small burn marks scarttered on the board bolted to the caps.
Old 12th July 2005, 04:04 PM   #16
Here is the schematic I have for the PCR 800.
Blessings, Terry
Old 12th July 2005, 04:34 PM   #17
oPossum's Avatar
Are the burn marks on the bottom of the board? Take a carefull look at the top of the big caps. Compare to this picture . Notice the blown vent of one cap. Some caps have black vents rather than white, so it may be hard to tell if it has vented. Burn marks on the circuit board directly above the vent is a sure sign the cap has died.
SCR is Silicon Controled Rectifier. It is a triggerable diode. There are four along one side of the board, they have a small heat sink. They are used as the bridge rectifier in these amps. Voltage regulation is done by changing the phase angle they trigger at (PCR - Phase Control Regulation).
If you don't have experience with electronic repair, it is probalbly best to just replace the caps. Make sure the polarity is correct (+ to +, - to -).
Old 12th July 2005, 05:12 PM   #18
oPossum's Avatar
Carlos: Do you build a new amp every week?
I have a collection of Soundcraftsmen shematics at www.soundcraftsmen.info
The PCR800 is very similar to the 450x2, and ProPower 1,3,4 & 10. It is rated at 205 W per channel at 8 ohms, and 325 per channel at 4 ohms. This is by far the most common Soundcraftsmen MOSFET amp design.
Hitachi MOSFETs where used until they stopped production, then Exicon MOSFETs where used for a few years.
Most of the MOSFET amps have a Phase Control Regulation (PCR) power supply.
Terry: Do you have a larger version of that schematic that you could send me? Power supply too???
Old 12th July 2005, 05:23 PM   #19
Yes I do. Let me dig them out. A fellow sent them to me through snail mail a while back. Let me search for them and I'll get back to you. Send me an email so I won't forget. These threads get buried sometimes. Out of sight, out of mind.
Blessings, Terry
Old 12th July 2005, 05:53 PM   #20
The burn marks (light brown squiggly lines) I saw were on the top side of the board. I'll try to take some pictures of what I see and post them. I don't recall the caps being vented, but I'll look again and try and take a picture of those too.
Thanks again.
Soundcraftsmen 900X2Hide this!Advertise here!
Soundcraftsmen Pre-amp enzedone Solid State 2 27th March 2007 02:07 AM
FS: Soundcraftsmen PM-840 410 watt amp $150.00 Zero Cool Swap Meet 0 27th May 2005 02:45 AM
Soundcraftsmen MA-5002a mhirvon Solid State 0 17th May 2005 10:52 AM
Soundcraftsmen troubles still4given Solid State 33 23rd March 2005 02:25 PM
Soundcraftsmen 220 mig-ru Tubes / Valves 2 16th July 2002 07:11 AM
