Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
Class-A Opamps
Class-A Opamps
Thread Tools
Old 3rd March 2006, 10:04 PM   #61
mikeks is offline mikeks  United Kingdom
Account Disabled
Originally posted by nuvistor
I wonder, what is the purpose of the 47p capacitors? the time constant with the 150R is 7ns.
Improve minor-loop stability margins...
Old 5th March 2006, 01:03 PM   #62
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Mike
Is this a machanism of introducing a zero for 'miller-type' pole?
Old 8th March 2006, 07:05 PM   #63
Account Disabled
Originally posted by darkfenriz
Mike
No...Miller compensation rolls off foward path gain by increasing minor-loop transmission about the second stage....This is denoted by a pole in the foward path gain-frequency response..
It follows that the reduction in foward path gain must simultaneously be accompanied by an increase in minor loop transmission about the second stage...denoted by a zero....
Bypassing the second stage's emitter resistor merely increases minor loop transmission at ultrasonic frequencies...near the local loop's unity gain frequency....ergo...introduces yet another arbitrary zero....which enhances stability in the local loop.....
Old 8th March 2006, 09:16 PM   #64
darkfenriz's Avatar
Do you mean local miller integrator might need a zero for better stability?
I remember Horowitz saying like "one must be extrmely talented to make an integrator instable".
How about integrator around one device?
Is this really an issue?
best regards
Old 8th March 2006, 09:58 PM   #65
Account Disabled
Yes...and No...you do not have to be 'extremely talented' to make the second stage of an op amp. unstable...Just enclose three or more transistor stages within the loop...
Old 24th June 2007, 10:25 AM   #66
lineup is offline lineup  Sweden
lineup's Avatar
Thumbs up Graham Maynard 25 Watt Class-A JLH based amplifier
Originally posted by lineup
Generally, why is almost no Chip OP-amplifier in Class A
I think is
when you go for an IC ( and not discrete ) Operational amplifier
- you want it simple
- you want it as low power supply as possible
- you might want to build a great number of identical devices
If you want to find TRUE Class A OP-amps, you have to go for discrete.
Like this one by Graham Maynard:
http://www.mitedu.freeserve.co.uk/Ci...dio/preamp.gif
Hi-Fi Preamplifier by Graham Maynard
Originally posted by amplifierguru
Hi lineup,
There are many modern op amps
that operate enough standing output stage current
that they will operate Class A into av high Z load
- so they can be lightly loaded with a discrete buffer stage.
Class A may be a goal in itself in low power and preamps but in power amps it's generally a wasteful fallback position.
Cheers, Greg
Hi, Greg Guru.
I am still not convinced enough to begin to replace
my Class-A discrete pre amplifiers and power amplifiers.
And if I will build myself a new pre/power amp ( in case I have ANY USE for another amp )
I certainly will go 100% Class-A, push-pull complementary or quasi-complementary.
Like for example Graham Maynard Class-A (based on work of JLH, John L. Hood ).
See my ATTACHED SCHEMATIC
This is in my Lineup Audio book,
how a good Audio Amplifier should be!
Audio Regards to Australia, all kangaroos and amplifierguru
lineup
More info, background and description at Graham Maynard
website
http://www.gmweb2.net/
Latest published version of GM25W Class-A is 2007-01-26
Cheers & have some bears. Russian Bear is great & big!
lineup
Old 24th June 2007, 03:21 PM   #67
jcx is offline jcx  United States
B.VDBOS skectch for biasing monolithic op amps class A wasn't too far off
I've acutally built a monolithic op amp headphone amp that is biased Class A for up to 400+ mA ~ 5W into 60 Ohms
http://www.head-fi.org/forums/showth...12#post2276512
scroll around that thread for my (jcx) posts showing a rather extreme implementaiton
basic principle:
Old 24th June 2007, 07:44 PM   #68
lineup's Avatar
thanks
for your interest jcx
now, it is with amplifiers
as is with eat ice-cream
... to each his own ... by the taste of his tongue
.... what is TASTELESS to one, is something ELSE for one other
lineup with pen ... not with his tongue
lineup
Old 27th August 2008, 01:02 AM   #69
lineup's Avatar
Class A IC-Chip op-amps do not exist.
At least not manufactured in any quantity and so commonly found for us.
To single end bias the output stage of one Class AB op-amp
will not give you one Class A op-amp.
Because the op-amp was designed & calculated for a specific output stage operation
= Symmetrical Class B / Class AB, in 90% of all known cases.
If you want Class A op-amp, you must go discrete.
There are plenty of discrete transistor operational amplifiers in Class A.
In fact, it is more The Rule than the exception.
all sorts of, JFET or BJT input, complementary or one LTP differential pair inputs.
Because when a good designer is left with the choice,
he will go Class A all the time, if there is no special thing against it.
And most often is not. Except for Power Op-Amps applications.
lineup
Old 2nd September 2008, 10:21 PM   #70
EWorkshop1708 is offline EWorkshop1708  United States
Default Re: Re: Re: Class-A Opamps
Originally posted by EWorkshop1708
Too bad I found your post AFTER I built a small preamp using a 324
But thank your for that valuable information.
Wow, old posts!
I now use an MC33079 opamp with 0.002% THD and am VERY pleased. No other changes to the preamp other than changing the IC chip.
Class-A OpampsHide this!Advertise here!
biasing opamps in class a matjans Chip Amps 36 20th February 2013 02:16 PM
low distortion measurements and forcing opamps to class a mlloyd1 Solid State 3 3rd July 2009 12:05 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Class A biasing of opamps DrewP Solid State 25 23rd October 2002 11:18 PM
Why do so few designs use opamps working in class A? fmak Solid State 19 23rd May 2002 03:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
