Another amp
i finaly set my bias right....
at 54V rail, it worked to set it at 1.8 mA...
the amp is working fine but,boy is it getting hot..., and i don't mean the final transistors, because i have a huge heat sink, and a big fan...
but the mje340/350, and the mje 15030/31 are getting hot..., i supose i will put them a bigger heat sink...
the amp, sounds good, easy to build...nice sound, cheap...
i can hardly wait, to test it on a osciloscope, to see how it preforms there...
For any persons Interested, I have Cleaned up and Re-Drawn the Schematic.
http://www3.telus.net/chemelec/Projects/Misc-PCB
I Agree with: amplifierguru, Especially on the Supply Rails.
The Amp that I Designed and currently use is Less Power than this one and I used a Decoupling circuit on its supply rails.
So I plan to make a Few Revisions on this one in the near future.
Probably also a revised board at some point.
But it is Becoming Gardening Time so that may be awhile.
Take care...........Gary
PS: I'll give it another week and than Anounce the Winner.
Before committing myself to ordering all the parts I need, I have a few questions for those that have already built them or are in the process of building theirs. BTW: I live in the US.
1. I know of several places to get most of the parts (Avnet, DigiKey, Arrow). What places do you people recommend?
2. Where can I get a heat sink of such large proportions (like the one pictured on the author's web page)?
3. Since there is a huge variety of parts, what kinds of capacitors are used? (I'm used to seeing the ceramic and electolytic...not the square ones that are pictured.)
4. I'm planning to build a dual-channel amp. Will the power supply be sufficient to run both channels? (I will be using a 500VA 2x37 Torid).
Thanks in advance.
desert00rat said:
[B
[/B]
500W is sufficient for both channels only at 8 ohms... for 4 ohm, you should use a bigger transformer...
also, i think a 37V ac is a bit low...(50V cc)
i am using a 550W normat transformer, 44V ac, 58 cc...
C3,4 -normal, electolytic
C2,5,8-ceramic
C1,6,7-have to be non-polar,non-electolytic , and also non-ceramic ... there are lots of other types(i just don't know how they are called....), for ex: mkt, film , multy-layer...
and C7 has to be at least 200V...
the transstors, 15030/31 work in class A or class AB...???
the pcb's arrived and they r good
And the final question is:
is it absoloutely essential that the amp runs off a dual rail power supply. it's just that i've found a tordial transformer in RS which has 2 55 volt outputs and if i use it as a dual rail it will give me an output of 110v- the same as in the us
there is NOTHING wrong in the schematic....
it works fine...
the amp run's on dual power suply...
a simple power can NOT be used...
if the transformer has an output of 2*55V AC this will be 2*75V dc,and you can't use this much voltage..
i would sugest a 2*60V dc max
is this your first amp??? if it is i would sugest you read a little more about amplifiers...
after you build it before testing it relace the fuses with a 50-120 ohm 3-5W resistor ,because if you did something wron smoke will come out of these resistors and not out of the output transistors :D
