Soundcraftsman MA5002 Bias
Old 11th February 2019, 11:02 AM   #21
Depaj is offline Depaj  France
Yes I know but that's one piece of equipment I still have to buy and they aren't cheap.
Thank you, I will set it at this, leave it for a while, see if it drifts, how heat sinks feel and check scope for crossover although that's probably not very accurate.
Thanks for your help
Old 11th February 2019, 11:07 AM   #22
epicyclic is offline epicyclic  United Kingdom
Sounds like a good plan to me . Glad to have helped
Old 11th February 2019, 12:11 PM   #23
Bias stays nice around 15mV (+/- 0.5mV), heat sinks are slightly warm and I don't see any crossover notch.
The only thing left to do now is check out that power meter and see what's wrong with it.
I did already verify and they do get the same voltage across their terminals.
Old 11th February 2019, 05:46 PM   #24
Last problem has been solved, I disassembled the power meter that was weak and completely cleaned it : the back spring got stuck to the back of the casing. They now track pretty closely.
Soundcraftsman MA5002 BiasHide this!Advertise here!
Soundcraftsman PM860 HotKava Solid State 0 1st August 2008 04:45 PM
Soundcraftsman MA5002A rick8110 Solid State 0 17th February 2006 11:49 PM
Copyright ©1999-2019 diyAudio
