Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#1711 |
This is a very short movie clip of my transformer coupled Sub-Bass speaker in action, it really is running this slowly it is not a video-effects speed-change.
The Driver is a Vibe SPACE 15D4, 15 inch (ca. 38 cm) 3600 Watt Subwoofer. |
#1712 | |
diyAudio Moderator Emeritus
https://www.facebook.com/tony.tecson |
#1713 | |
That's what I expected ![]() Can you explain the sonic benefits of your circuit to normal follower circuits (tube, solid state).... my experience on the common circuits are sonical not the my "cup of tea" but maybe your findings look interesting to me. |
#1714 |
Someone has STW34NB20?
Or Other Susan suggested for the project? Matched would be better. Thanks V |
#1715 |
After a lot of time spent looking for 'unobtaineum' - and any pspice models for them - I found what appears to be an upgraded IRFP250
Available from RS Components - one of the cheapest of this series IRFP250MPBF - RDS on 0.075 ohm, Crss 83p , 17 S , Vth 3v STW34NB20 - RDS on 0.075 ohm, Crss 90p , 17 S , Vth 4v vs IRFP250 - RDS on 0.085 ohm , Crss 240p, 12 S Which is what I'm going to roll with . Somewhere in this long thread is a discussion of the improvement in THD due to the lower Crss of the STW34NB20 , and given the lower Vth and low cost , I'm going to roll with this one . Hope this helps someone .. PG |
#1716 |
Awesome; the IRFP250MPBF do indeed look like a good match
![]() Thanks for the post, appreciated. |
#1717 |
Admitted. Good amp, smart supply. A good reference!
Y/Yo=(1-X/Xo)exp2 <> Y/Yo=(e)exp(X/Xo){Xo=kT/q} |
#1718 |
The 19” 2U front-panel for my tube/bipolar hybrid line-driver has finally come back into stock with Farnell, so I have finally been able to finish this preamp project.
I also made some feet (white ABS). Using my HP8903B with a 1kHz test tone, THD is 0.018% with a 500mV input and 1.2V output into 600 ohms. ( For comparison the HP8903B loopback distortion measures 0.0044% ) FFT shows input at -10db, and 3rd harmonic at -90db. Total current at a nominal 24 volts is 0.68 amps. N.B. I made a nice little DC/DC converter to give a 120 to 200 volt anode supply for the tubes, but that proved not to be needed as the 7N7 vacuum-tubes are running with the 24 volt supply for their anode B+ volts. Last edited by Susan_Parker; 29th November 2020 at 03:36 PM. Reason: Attachments didn't... plus added test plot |
#1719 |
Just to avoid sweeping through 1700 posts, but what's the final circuit look like? Curiosity.
#1720 |
Hi MarsBravo,
The current schematic in PNG and a PDF version with suggested transformer sets. The hybrid line-driver replaces the DMOS MOSFET with a triode/bipolar follower. In the current prototype as just posted the line-driver (left side of schematic) is push-pull not single-ended. Last edited by Susan_Parker; 30th November 2020 at 09:43 AM. Reason: Make more sense... hopefully. |
Thread Tools | |
New To Site? | Need Help? |
