New error correction amp
Old 11th October 2010, 01:41 PM   #101
PMA is offline PMA  Europe
PMA's Avatar
Here are some new measurement results of the 'revived' PM-AB1 amplifier. Distortion is measured close to clipping, at 25W/4ohm.
Old 3rd January 2011, 11:00 PM   #102
Bigun is offline Bigun  Canada
Bigun's Avatar
Wow, those results look really impressive. I may have to revive my thoughts on making a hubrid tube + buffer using this idea for a buffer - although the input impedance will need to be low enough.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
New error correction ampHide this!Advertise here!
Re: New error correction amp mefistofelez Solid State 12 7th October 2010 06:55 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Will this work as Error Correction? lumanauw Solid State 4 8th October 2004 10:52 AM
Copyright ©1999-2019 diyAudio
