how to make a clean square wave?
Old 6th September 2004, 09:32 PM   #21
Lars Clausen is offline Lars Clausen  Denmark
1 x f + 1/3 x 3f + 1/5 x 5f + 1/7 x 7f....
If f=1 kHz, isnt 3f then 3 kHz?
And since 1/3 x 3 kHz is 1 kHz, isn't then 1/3 x 3f the same as 1 x f ?
So 1 x 1f + 1 x 1f + 1 x 1f ... or just infinity f
Did i miss something?
Old 6th September 2004, 10:27 PM   #22
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
I think what it should be is a bit more like the thing below (try typing that into v-bulletin) which holds true of all repeating signals, not just square waves (they just hapen to have much larger percentages of the higher harmonics than some other signals like sine, or triangle waves).
File Type: gif fourier equation.gif (557 Bytes, 88 views)
Old 6th September 2004, 10:37 PM   #23
Mr Teal is offline Mr Teal  Canada
Lars, what he meant was 1A x 1f + 1/3A x 3f + 1/5A x 5f ... etc, where A = amplitude.
Old 6th September 2004, 10:55 PM   #24
HFGuy is offline HFGuy  Canada
Default Who says Math cant be fun ?
Fourier Series of a Square wave
x(t) = ∑ (4V/ k* pi) sin (kwt) V = amplitude
k =1
Where k is odd
So basically you get the fundamental w (angular freq) and odd harmonics decreasing at a rate of 1/k
w = 4V / pi
3w = 4V / 3pi
5w = 4V / 5pi
and so forth until finity or you stop caring
how to make a clean square wave?Hide this!Advertise here!
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
