DC Offset with Cap Coupled Amp
Thread Tools
Old 25th September 2021, 03:23 PM   #31
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Sometimes audio ground is isolated from power gnd by a conductive network like a high valued R like 100K and a cap of,say, 0.1uF. Other uses two diodes in antiparallel. Perhaps some leak current is the cause of such voltage drop. One example may be Y caps in the ungrounded kit. Also contact potentials between joining of different metals can give up to 1V across them.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 25th September 2021, 04:21 PM   #32
indianajo is offline indianajo  United States
indianajo's Avatar
Originally Posted by Osvaldo de Banfield View Post
His amp is motorboating. In my experience, never a tone control stage had caused such a symptom. Nor a small film cap. Usually it is as a consequence of improper bypassed power supply, be by bad design, be by degraded caps.
He has a scope reading of jumps up near C105 or C106. Near those and the bass pot. Plastic film caps are usually reliable, but not always in 1965. SCR cap of France became notorious on this forum. Some vendors had trouble spraying the metal paste properly to not leak across the ends. I got some leaky film caps, 90 kohms @ 2 volts, from a surplus house. The picture OP showed is not one of the usually reliable brand film caps. It is not unheard of in 1965 for this to be a paper dialectric cap, which have definitely deteriorated in some of my 1964 organs and 1961 dynakit products.
The electrolytic suggestions are to ease implementation of your suggestion about the power supply cap, c3 on power supply board?
He can do further scope probing while a box grinds its way through the postal system. 8 days on some boxes, 32 days on another? Yes, USPS can move 2 day rate boxes in 2 days, sometimes. FedEx took 8 days on a surface rate box from AZ in August. Too many workers in a Colorado hub out quaranteened, and fires in Oregon & California closing hubs. Tubesandmore.com is in AZ.
I'd buy every electrolytic cap in the amp in the same box. they are going to fail one by one if he uses this more than an hour or two. I used a 1961 amp ~20000 hours and a 1970 amp ~14000.
Dynakit ST70, ST120 (modified), PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800s, M-2600, MMA-875T, SP2 (2004) speaker, PV8 mixer, Herald RA88a mixer (modified), Steinway console, Wurlitzer 4500, 4300
Old 25th September 2021, 05:10 PM   #33
1964 caps. Ha ha ha. It was in 1969 when I was born. So whatsever hapeded prior to it, is a mistery.
Old 25th September 2021, 05:26 PM   #34
dbxdx5 is offline dbxdx5
Thanks Oswaldo and indianajo. I appreciate both of you sticking with me on this as I try to sort out what the heck's going on. This combined tone/amp board design makes me appreciate receivers and integrateds that have main in/preamp out jumpers even more.
Oswaldo: I've attached the full schematic of the preamp, tone, and amplifier sections, as well as of the power supply. Hopefully, the resolution is good enough.
I tried disconnecting the amp board from the tone controls at C3 on the amp board. No change; the issue persisted. I still need to replace those caps (C2 and C3) on the power supply board. Stay tuned.
indianajo: Thanks for the tip about axial caps at justradios.com I do often use the Vishays, but they add up $$. As for the cans, I've gone both ways. If I'm fixing someone else's gear and they want to spend the money, I'll get them from Hayseed Hamfest. But if it's just for me, I'll either restuff the originals or bypass them using terminals strips and radial caps like you suggested.
Old 25th September 2021, 06:18 PM   #35
Resolution is OK for me. I'm viewing it in a small screen.
Please, acclare to me where are you seen the problem. At loudspeaker output or somewhere inside the circuit.
The audible difference between 1Cent cap and a 100U$S is negligible. So don't worry about it. It is only a question of Marketing. Pure marketing as Messi is.
Do you have a 50W light bulb of the filament type? If is the case, wire it at the lousdpeaker's terminals almost in one channel. And tell me what do you see in it.
Last edited by Osvaldo de Banfield; 25th September 2021 at 06:26 PM. Reason: Wrong words
Old 26th September 2021, 02:50 PM   #36
Some equipment won't get fixed without a fight. Sigh.
The amp boards are sandwiched together pretty close, and a slip of my scope probe took out Q4, Q5, and one output in the right channel. I replaced Q4 and Q5, and installed a different set of outputs. Now that channel isn't biasing up--turning the bias trimmer has no effect. My DC balance voltages look fine, and I've tested most of the components in the area, with the exception of the caps. The anomaly I'm seeing is at Q4 in the right channel. It tests fine out of circuit.
Q4 (Left)
E: 35.7
B: 35.3
C: 1.11
Q4 (Right)
E: 35.4
B: 34.7
C: 0.62
Something pulling down the voltage at the collector?
Old 26th September 2021, 02:56 PM   #37
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
LOW valued resistor like 10 Ohm 2W.
Haven't read the whole thread but C404 should be at least 4700 F if the device is meant to drive real loudspeakers. Are all the rectifier diodes checked? I have had my share with very old diodes causing strange things.
It's only audio. Member of the non modular PCB design committee.
Old 26th September 2021, 03:30 PM   #38
indianajo's Avatar
With no signal, I'd pull one leg of C114 to see if it is leaking. Part of AC comp I'd guess, so at DC not important. Test with circuit, not the 2v stress of a meter ohms scale.
"Tests okay" after a high voltage transient is a gloss. Things like D1 can be fine at 2 v the meter tests at, but leak like a sieve at 35 v. I test stressed parts with 12 v through a 47k ohm resistor, then the microamp scale of the DVM. Couple of microamps, the parts is okay, 255 microamps the parts is breaking down. Works on C to E of transistors too with the base disconnected.
Warning, modern transistors for 1965 parts, especially ones out on an external heat sink with long leads, can oscillate. Much higher Ft after epitaxial was invented. 10 ohm 1 W resistor as base drive instead of the wire is the usual correction.
Answer to Jean-Paul's prompt, 4700 uf caps in 1965 were very expensive. This amp is designed to run with 1000 uf for C404. More would require some part to not stress the transformer at turnon. Also more C404 could add to bass thump at turn on. Carefully designed 1965 amps didn't thump at turn-on, although they didn't have the half dozen silence at turn on parts later circuits had. My ST120 dynakit doesn't thump,1966 design, & uses 3300 uf rail cap for two channels @ 60 w/ch. I've gotten 70/ch w out of it for 5 seconds with MJ15003 outputs instead of original RCA selected 2n3055. 40111 was it? burned transistors had a dynaco PN on them. Still a single 3300 uf rail cap.
Old 26th September 2021, 03:40 PM   #39
jean-paul's Avatar
It was then more or less like that. Large values were physically too large for equipment and they were indeed too expensive. If designers would have had 2200 or 4700 F caps in todays sizes they would have used them Since the amplifier is AC coupled the turn on thump will not damage much I guess.
What about the spikes? Can they be seen on the PSU voltages?
Old 26th September 2021, 05:19 PM   #40
I'll try lifting C114. And to your point about things testing ok and failing in circuit, I was wondering if D1 really is ok. Any suggestions for what I can use there? Even accessing it for testing is a bit of a pain, and I might just replace it.
Re the outputs I swapped in, they're matched RCA 2N3055s I had on hand.
DC Offset with Cap Coupled AmpHide this!Advertise here!
Thread Tools
capacitor coupled vs. direct coupled ouput hugobross Solid State 18 8th October 2019 09:47 PM
Need Opinion: Comparative Sound of Pass Cap-Coupled (Zen) vs. Direct-Coupled Designs Diogenio Pass Labs 46 24th January 2019 01:38 AM
cap coupled output combined with cap coupled input? nightanole Analog Line Level 9 24th July 2010 08:34 PM
Coupled or de-coupled cabinents troystg Multi-Way 12 20th October 2004 10:34 PM
Can someone explain parafeed & direct coupled & a.c. coupled? mwmitchell Tubes / Valves 2 11th September 2002 01:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
