LEAK Stereo 70  Amplifier Information Wanted
Thread Tools
Old 21st July 2021, 05:02 PM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default LEAK Stereo 70 Amplifier Information Wanted
Hi All,
Does anyone know what size screw thread is used on the securing bolt for the case.
I know it's not metric. is it BA BSF or something else?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 21st July 2021, 05:10 PM   #2
NareshBrd is online now NareshBrd  India
If it is less than 1/4", could be BSF, larger are BSW...
BA, BSP, and UNC are not likely in British equipment.
Old 21st July 2021, 05:22 PM   #3
ejp is offline ejp  Australia
BA is extremely likely in British equipment. It stands for British Association. We were just discussing the Quad II which is full of them, 2BA, 4BA, and 6BA.
Old 22nd July 2021, 02:42 AM   #4
BA size chart
The tpi figures are way odd, would need special taps...
Change over to whatever is easily available at your local source, if that is easy to do.
Old 22nd July 2021, 04:30 AM   #5
Ian Finch is offline Ian Finch  Australia
As far as I'm aware, BA threads were common but not universal in british audio gear of the 60's -70's. BSF threads were also used to by some manufacturers, apparently in line with their field of use, such as tag strip mounts. BA thread is a scientific instrument and modellers thread that would be found in meters, test gear and precision gear generally but chassis assemblies were often held together with BSF and occasionally, even BSW threads were used with lockwashers to fasten items like rubber feet (bumpons).
I think it best to check the turns per inch (TPI) of any existing screws and compare BSF and BA threads from the appropriate wikipedia page articles on those threads or, for another example, see here: BA size chart and:BSW & BSF Threads
FWIW, counting thread TPI isn't so hard if you use a small screwdriver blade to count the "clicks" as you run it down a measured length of thread - easier than holding it steady enough to peer through a magnifier at least.
Old 22nd July 2021, 07:55 AM   #6
Bruce@bluff is offline Bruce@bluff  South Africa
BA thread is mostly used for model engineering. In the UK companies like Blackgates will stock a wide range of BA nuts and bolts
Old 22nd July 2021, 11:39 AM   #7
Pingrs is offline Pingrs  United Kingdom
Note that 0BA and 6mm have the same diameter and thread pitch, but the thread forms are different. Can cause confusion.
  Reply to this post
LEAK Stereo 70  Amplifier Information WantedHide this!Advertise here!
Thread Tools
Leak Stereo 30 Plus and Stereo 70 Brucev Solid State 4 19th May 2018 07:35 AM
HELP needed - LEAK Varislope 2 Stereo + Stereo 20 with pictures... triole1 Tubes / Valves 13 28th March 2014 06:55 AM
Wanted: LEAK TL 25 Plus Tube / Valve amplifier conus Swap Meet 0 18th January 2014 03:22 PM
Leak Stereo 30+, Stereo 70 & Delta 70 (UK sale) Tweedle12 Swap Meet 2 13th April 2012 11:32 PM
Mods on leak stereo 20 bronto64 Tubes / Valves 22 26th April 2004 08:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
