Nad 3020A developed problems
Thread Tools
Old 13th June 2021, 05:32 PM   #81
Peterbt is offline Peterbt  France
Okay. I won't then. If that switch is defective I don't know if it's possible to get hold of a replacement one. Should I resolder the white wire to the switch as it was or just let it be right now?
Old 13th June 2021, 05:32 PM   #82
Mooly's Avatar
Your not missing anything I spotted that as well but I'm just looking at the fact it works with it disconnected and that the control comes up to the expected 13 volt or so.
So the switch has to be conductive.
Erm... I know some of the resistance checks have been a bit open to interpretation shall we say and so I'll put the readings down to that. Sometimes it can be difficult to get a probe to connect through flux and grime... it all comes with experience.
Peter... just swap the wires over from one side to the other and see if it works.
I was actually going to say Deoxit might be worth a try to free things up but again experience comes into play and you don't really want to be filling the mains part of the switch with anything that could cause arcing. You would have to direct it into the top part of the switch where that little spring is (not the coil spring, the other little actuator thingy in that groove... assuming it looks exactly like the picture.
Feeding time
Old 13th June 2021, 05:34 PM   #83
Mooly's Avatar
Swap them over, see if it works.
If it doesn't then leave the wire disconnected for now. Make 100% sure it can not touch any live parts accidently.
If you can't get a switch then get a 4.7meg (4.7 million ohm) resistor and solder it across C531 and leave the switch disconnected.
Definitely feeding time now
Old 13th June 2021, 05:39 PM   #84
Goldie99 is offline Goldie99  United Kingdom
Peter - in the last photo I posted, with the 2 yellow lines & 2 orange lines, you can relocate the wires to the 2 orange terminals, again the order doesn't matter - they're just a second set of terminals which are identical to the first set, but have never been used, so may be cleaner.
If the top (outside) of the switch is dirty, it would be worth taking a pipe cleaner and cleaning it with something like IPA, it's just possible there might be something conductive on the outside of the switch.
Old 13th June 2021, 05:39 PM   #85
Okay, thanks. I will and I pass on the Deoxit if it's that touchy. Yes feeding time.
Old 13th June 2021, 08:34 PM   #86
I've swapped those wires but no change.Still no sound. I'll disconnect the white wire again. Could you give me the color code for that 4.6 meg resistor? I don't think I have any but it may be easier to look for one. Thanks
Old 13th June 2021, 11:15 PM   #87
indianajo is offline indianajo  United States
indianajo's Avatar
Yellow violet green. Unlikely to be stocked. I never owned any.
Dynakit ST70, ST120 (modified), PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800s, M-2600, MMA-875T, SP2 (2004) speaker, PV8 mixer, Herald RA88a mixer (modified), Steinway console, Wurlitzer 4500, 4300
Old 14th June 2021, 12:27 AM   #88
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
for such an aging amp, a recapping is timely..
Old 14th June 2021, 06:05 AM   #89
Mooly's Avatar
Firstly Peter... how do you feel the amp behaves with the wire left disconnected? I was just thinking a bit more on this.
Are there any problems with excess noises (bangs, thumps etc) as you turn the amp on and off with the mains switch and I'm actually thinking more of noises at switch off now.
The resistor I suggested would not actually help much with noise at switch off. When you turn the amp off the switch connects the mute circuit to the negative supply and it relies on that negative supply lasting long enough (as the caps discharge) to hold the amp in mute while the main amplifier power supply caps also discharge and the whole amp then stops functioning.
I have some other ideas on the switch itself. You say it is very dirty. How confident are you of putting some paper towel under and around that first part of the switch, then hold the amp vertically on its front and give that switch area a good clean with your spray. Work the switch on/off many many times and use the paper to absorb the gunge. Flood that part of the switch with cleaner but keep the amp vertical to stop it running into the mains area of the switch.
(By disconnecting the switch and also you confirming the voltage is correct on D507 we have proved beyond doubt that leakage is the problem)
Old 14th June 2021, 06:08 AM   #90
Mooly's Avatar
It could very well be Tony but always best to fix the original fault first I think.
Nad 3020A developed problemsHide this!Advertise here!
Thread Tools
NAD 3020A schematics or parts list ZuMbAiU Solid State 27 21st October 2014 08:52 AM
NAD 3020A Schematic JDeV Solid State 9 10th November 2007 05:14 AM
need help for NAD 3020a vubkevin Solid State 23 26th September 2007 07:18 PM
NAD 3020A -info and reapir thread> ZuMbAiU Solid State 24 28th February 2006 04:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
