Nad 3020A developed problems
Thread Tools
Old 14th June 2021, 10:48 PM   #111
Peterbt is offline Peterbt  France
Thanks all of you for the suggestions and help. I took the front panel off and removed the little lamp so that the switch would be more accessible. Cleaned it and sprayed inside with a 3 in 1 spray which penetrates but evaporates fast unlike Deoxit. I used the paper towel trick as Mooly suggested. Soldered the wires back on reconnected it and lo and behold the sound came right back on after the 5 second muting process. You were 100% right it was the switch. I'll probably have to change it eventually if it acts up again but as you mentioned it 30 bucks is quite a lot for a switch. Pounds, excuse me. Poundy sent this Ebay link for an original NAD switch from Germany but with shipping that was quite pricey too. But they said it was original. Anyway, right now it functions very well, thanks again
Peter
Old 15th June 2021, 07:25 AM   #112
Mooly's Avatar
Excellent I'm pleased it worked. It is (was) a very strange fault in all fairness, I can't actually remember anything quite similar tbh.
Enjoy
Old 15th June 2021, 08:31 AM   #113
Goldie99 is offline Goldie99  United Kingdom
Yes, a good result - and a lot easier & cheaper than having to change the switch.
Mooly - thanks also for the additional LTSpice examples - I'd been wondering how the switch function could be easily incorporated into the simulation... turning ON was straightforward, turning OFF less so (I haven't used the PULSE option before)
Old 15th June 2021, 10:09 AM   #114
Mooly's Avatar
There are loads of ways in LT to do the same thing.
Try this one using a voltage controlled switch.
File Type: asc NAD FET Muting Drive Circuit revised mod.asc (2.3 KB, 2 views)
Old 15th June 2021, 10:46 AM   #115
Cheers Mooly - looks good. I'll have a play with that once the sun's gone again !
You forgot R549 (390R) by the way - not sure why it's there, except maybe some sort of time constant with C531 ?
Old 15th June 2021, 11:05 AM   #116
Mooly's Avatar
I think to protect the switch contacts from dumping the (oh hum) 'large' discharge current from the cap. It would be enough to pit the contacts over many operation... but maybe that would have helped the switch in other ways
Old 15th June 2021, 05:19 PM   #117
mjona is offline mjona  New Zealand
Air borne contaminants and moisture can compromise switch contacts. I had a magnetic cartridge go open circuit due to where my record deck was situated. I now have a couple of small gel packs under the lid.
  Reply to this post
Nad 3020A developed problemsHide this!Advertise here!
Thread Tools
NAD 3020A schematics or parts list ZuMbAiU Solid State 27 21st October 2014 08:52 AM
NAD 3020A Schematic JDeV Solid State 9 10th November 2007 05:14 AM
need help for NAD 3020a vubkevin Solid State 23 26th September 2007 07:18 PM
NAD 3020A -info and reapir thread> ZuMbAiU Solid State 24 28th February 2006 04:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
