NAD C352 Protect mode
I came across a web, one of the photo showed the C352 mainboard,
there is a 200 ohm 5w resistor in the middle of the 4 heatsinks,
you can check if that is the R245,
suggest you post a detail photo of the inside,
so members can know more about the amp.
you mentioned about P102B, pin1 +50v, pin2 -40.5v,
unplug it and measure it if the voltage will go back to +50v and -50v.
you must solve this imbalance voltage first.
if imbalance persist, go to page 4, Power Supply.
check all the components,
SCR, transistors, resisters, capacitors...bad joints
also
measure P101B,,
the two AC connections , ac voltage to ground,
check R251 voltage,
12v became 26v out means Q159, Q160 could be defective, may be coursed by shortage somewhere, if found defective take it out first, replace only until you found the fault
and fix.
for the + -18v, do your best to find any short along the rail.
the circuit, make sure you fix everything ok .
also
measure P101B,,
check R251 voltage,
and fix.
R245 is 33 ohm 0.5w resistor
Thanks for the C320 PDF, Alexchoi,
So refreshing to have a schematic that isn't riddled with omissions -- and they didn't run out of little black 'connected' dots!:D
Looks like we'll need to agree / to stick with / or cast aside / C352 component designations, though. The very section we spent most of our time on -- the ±18V regulators -- has both 2 digit, and 4xx-series numbers. The C352 schematic is all 100's for Q's and C's, 200's for resistors.
Looks like any of the circuits that hold down Trig, like Q154 (C352) or Q421 (C320) have the job of keeping the power supply SCR's off, lowering voltage and/or current capability.
Cheers
I just learned how to insert link,
here's the photo link, it is one of the three images.
But again the link can't be shown here,
I've edit the photo but don't know how to post it here.
suggest to use a 5w 200r to replace R245 temporarily to locate the faults,
change it back to 33r 0.5w when everything fixed.
have you measure the ac voltages,
hope you fix it soon.
200r 5w resistor
here I try to upload the image
