Removing MJE1503x in an Output Triple
Thread Tools
Old 23rd February 2021, 11:15 AM   #31
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
Originally Posted by jaycee View Post
AS long as you dont mind another device on the BOM, perhaps look at KSC2690/KSA1220
This is what I’m using in my EF3’s, followed by 15033/33 then NJW’s (6 pairs). The VAS uses the usual 3503 and 1381
Here Ovation High Fidelity - Model 1721
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 23rd February 2021, 01:49 PM   #32
zergxia is offline zergxia  China
Originally Posted by BesPav View Post
Don't be scared, yes, i fully agree!
Just design EF3 with proper understanding like this one:
The YAP Output Stage
Sadly such an analysis aren't usual here at Diyaudio.
Dear friend, thank you for your valuable sharing.
Many medium power tubes have a higher FT than high power tubes. When the driver stage uses a high-power tube, it is slower than the frequently used medium-power tube.
I thought before that the speed of the driver stage should be fast enough to avoid becoming a bottleneck. So I tried to increase the quiescent current of the driver stage to make the speed of drives and outputs as same as possible. But the reality seems to be different~
It seems that I should connect a small capacitor in parallel between the B/C of the drive to appropriately limit the speed.
Will this cause a decrease in usable gain and deterioration of distortion performance?
Thanks again:p
Old 23rd February 2021, 03:00 PM   #33
BesPav is offline BesPav  Russian Federation
You are welcome!
tube
B/C
Hmmm...
You meant vacuum tube? Or base-collector junction of bipolar transistor?
Old 23rd February 2021, 03:22 PM   #34
Is BJT
There seems to be some small problems in translation~
Old 23rd February 2021, 03:42 PM   #35
Is BJT
Ok
Any medium power stage will be an order or two faster than audio amplifier need. So it will not become a bottleneck.
Yes and no simultaneosly.
No - slowering will not nor decrease gain, nor add distortion.
Yes - slowering (based on speed of the last output transistors) will limit effective bandwidth of the output stage. Because of this you will be limited in unity gain frequency and feedback depth at higher audio frequencies, say 10-20 kHz, without complicated high-order frequency correction methods.
  Reply to this post
Removing MJE1503x in an Output TripleHide this!Advertise here!
Thread Tools
stability issues output triple and high freq extension ? rhythmsandy Solid State 31 4th November 2015 09:23 PM
LME49810 using triple CFP output stage Mr Teal Chip Amps 16 18th April 2012 08:28 PM
Triple compound output amp stability rss388 Solid State 24 3rd April 2012 05:51 PM
LM4702 triple darlington output alexcd Chip Amps 24 16th June 2006 04:10 PM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 08:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
