b k electronics mosfet 100 watt modules
Thread Tools
Old 20th April 2021, 08:58 PM   #331
Shockhazard is offline Shockhazard  United Kingdom
Funny you should say that I’ve been getting these headaches and like you really tired must be something going around.
Think he contacted B&K about the faults it’s on here somewhere.
Appreciate that.
Well hope you feel better soon but I know what you mean.
My cat is a pain she loves to chew live wires. So she's great for testing live leads saves me getting the meter out.
Member of the radio museum
Old 22nd April 2021, 11:48 AM   #332
Totally unrelated but me bits came. That psu board 5mm thick. Managed to get some sk42 heatsinks only 12 quid each bargain. 5mm thick bloody heavy for size.
Anyhow not related but just wanted to show off ha. I might change out those resistors get some better quality ones. Think there carbon film. Hard to tell donít look metal film.
Iím going to draw out a new board for the unit but to exact size of original. Like said had to bend those legs on those transistors way too far apart sideways. Donít think there meant to be forwards yeah not sidewards. Would not surprise me if Iíve not cracked the internal substrate in them.
File Type: jpg 7D479533-168D-4793-8438-2931D4AAD77C.jpg (1.00 MB, 54 views)
Old 9th May 2021, 08:55 AM   #333
RS232 is offline RS232  United Kingdom
Any update ?
You didn't gave up on it did you ?
Old 9th May 2021, 09:49 AM   #334
No not yet moved over to a repair job someone who did not know what they where doing.
So the Matrix M400 fully up and running including the VU meter and fan plus some other bits. Needed a break from that one was getting to frustrated. Re drawn the pcb correct size this time on the tracks so just need to do some tidying up on paint shop then do the new board. Start all over again. I was gonna just add jump wires on the old board where the tracks are missing but not sure if that will work properly be fine on valve gear but not sure if the transistors would like it. That’s easy option what do you think?
Plus gathering all parts for F5 gonna build my own cabinet for that.
So I’ll give this BK one more go and if the readings on the outputs are up the creek again I’ll give it up. As it makes no sense at all the other board bang on and considering there’s no difference between them except the new transistors but it was way out on output before I even put them in. So all it can be is there is a short on the tranny as it warms up well you could fry an egg on it.
  Reply to this post
b k electronics mosfet 100 watt modulesHide this!Advertise here!
Thread Tools
Simple 100 Watt MOSFET using Dual Pairs of IRFP240/9240 lineup Solid State 9 24th August 2020 06:01 PM
100 watt to 150 watt Class A integrated amp desig coed1992 Solid State 7 28th April 2020 11:52 AM
100 + 100 watt TDA7294/12AU7 amplifier module nigelwright7557 Swap Meet 2 16th February 2018 11:45 PM
problem blowing up several sure electronics 4 x 100 watt boards jmmusicproduction Class D 57 2nd February 2015 10:30 AM
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
