Unity-gain "amp" for high-efficiency speakers
Thread Tools
Old 20th January 2021, 08:05 PM   #11
marconi118 is online now marconi118  Germany
2v rms in 100db speakers is ok for normal level listening
go for the mofo you wont regret
Old 20th January 2021, 09:52 PM   #12
U230421 is offline U230421
Originally Posted by mudihan View Post
I believe the calculator assumes that Vmin would be negative 5.7v, i.e., Vmax is half of Vpp.
I doubt...
Old 20th January 2021, 09:53 PM   #13
mudihan is offline mudihan  United States
Originally Posted by MarsBravo View Post
I doubt...
Vmax to Vrms conversion calculator.
Composing music>Playing Music>Listening to music>The equipments you use to listen to music
Old 21st January 2021, 02:37 AM   #14
U130421 is offline U130421  Antarctica
I use 600/10k adapter transformer 24$/pair at the input.
Old 21st January 2021, 08:44 AM   #15
You 'believe'... and 'the calculator assumes'... that's what I doubt.
Naming the half of Vpp as Vmax is confusing, name it Vp instead.
So still the question: what are the measured/actual/real voltages from the DAC output? Is this DAC running on +/-6Vdc (+/-5.7 Vpp out) or +6/0Vdc (+5.7Vpp out)?
1/2√2 is only valid for sine waves, but in general accepted for common (audio) signals.
Old 21st January 2021, 09:07 AM   #16
Where did you get them?
Old 21st January 2021, 02:24 PM   #17
See attached.
Old 21st January 2021, 04:57 PM   #18
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
It’s not a fancy discrete Class A amp, but you could use a couple of TPA6120A2 Class AB unity gain headphone amp chips in parallel and drive 8ohms. Those chips can have up to +/-15v rails. Capable of 700mA each so 1.4A when in parallel. Probably would drive 100dB sensitive speaker more than loud enough. These chips have phenomenal performance specs with regards to noise and distortion.
https://www.ti.com/lit/ds/slos431b/slos431b.pdf
XRKaudio Store // Manufacturer’s Forum
Old 21st January 2021, 06:00 PM   #19
I would vote for a mini mofo with 800mA bias.
Old 21st January 2021, 06:09 PM   #20
dkfan9 is offline dkfan9
More Class-A Amplifiers
Skip to the second half for something like what you're looking for.
If you go to the main page and ctrl+f "power buffers" he's got more posts on the topic.
Last edited by dkfan9; 21st January 2021 at 06:09 PM. Reason: excess space between lines
Unity-gain "amp" for high-efficiency speakersHide this!Advertise here!
Thread Tools
Unity-gain "amp" for high-efficiency full range mudihan Full Range 0 20th January 2021 05:11 PM
Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? tiefbassuebertr Solid State 9 9th June 2011 06:49 AM
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 01:23 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 01:47 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
