Ld1014d question about noise
It has a high transconductance and it must have a large die area, so chances are its equivalent input voltage noise level will be quite low. Current noise will be low(*) as long as you reverse bias the gate, which will happen automatically at 50 mA to 100 mA.
(*): Regarding noise current, a smaller JFET will be even better, but you will only notice that at very high source impedances, like those of condenser microphone capsules without built-in amplifier.
Here's the Zen9 "noise" -- to get flat frequency response (into a 6 ohm passive load) I had to increase Vds to 2.12, and lower the current to 1.6A. Gain is 21dB.
I've run the LU1014 on its own, not yet satisfied with the results.
In looking at the old Pass Bride Of Zen preamp it occured to me that it would be incredibly easy to modify it to a cascode using the Ld1014d like was done in the Zen 8. Heck with about 2.5v across the Ld1014d at 40ma it wouldn't even need any heatsink. I was just concerned with the noise. Wonder if it would sound better than the original.
