Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#101 | |
Noninverting unconditionally stable amp mostly anyway have different source resistances seen from its inputs. Now, just think, do it have equal voltage drop caused by input bias current? Do this drop equal to differential and common mode? Do this drop are equal through working signal voltage swing? Do this drop are equat through input common-mode range? ![]() So, what amp do you want now? Have no doubt, i'll prefer to keep amp inside known stability conditions and have +60 dB feedback handicap than use unconditionally stable miller-compensated first-order one. Last edited by BesPav; 12th January 2021 at 03:44 PM. |
#102 | |
Your AC input source, is it floating? or does it have a ground reference?
Ignorance is bliss |
#103 |
I might be wrong and I don't have access to any simulator to check it, but here's how I see it, the protection circuit for the output FET stage doesn't work as one might think, those 2 transistors Q15, Q16, and 2 diodes D3, D4, supposed to sense the voltage fall over the source resistors at 0,1 Ohm in the occurrence of a short at the output do nothing, or, almost nothing, because as we will soon see they do "protect" but in a peculiar way.
The lower side of the Vbe multiplier circuit, which is biasing the output stage, is during positive cycle clamped to the output through lower over current protection transistors collector-base diode + lower diode + source-R (Q16 + D4 + R26). And vice-verse during negative output voltage cycle, the higher side of the Vbe multiplier circuit is clamped to the output through the upper transistors collector-base diode + upper diode + source-R (Q15 + D3 + R24), hence these two transistors do not act on the voltage fall over output FET source resistors more than two passive diodes via their base-collector diode. And the reason the output clips harder for positive cycle is because the N-ch FET's have lower Vgs threshold than P-ch FET's, in any case the Vgs drive is always so low due to the clamping that the output FET's becomes self limiting without any protection circuit. To make the output protection circuit (consisting of Q15, Q16, D3 and D4) engage during a short, we would need at the very least some 0,6 Volt voltage fall for each of ALL 4 devices (Q15, Q16, D3 and D4), ie. 2,4 Volt, and 2,4V over R24 alone equals to 24 Ampere for one output device, which doesn't happen due to the clamping effect explained above, ie. the protection circuit doesn't work as expected. Last edited by Ultima Thule; 13th January 2021 at 11:57 AM. |
#104 |
![]() petr_2009 All your posts that are unrelated to this thread have been split off to here: Musings on amp design... a thread split. If you wish a different title then please report post #1 of the new thread and say what you want it to be called. Please in future do not hijack and drag other established threads off topic as you have this one.
Installing and using LTspice IV. From beginner to advanced. |
#105 | |
ps: Good split Mooly!
Y/Yo=(1-X/Xo)exp2 <> Y/Yo=(e)exp(X/Xo){Xo=kT/q} |
#106 | |
![]() Not entirely sure what you mean, the schematic as posted shows the balanced mode operation, which only applies to the input really, the output of the amplifier is single ended.
Mediocre is not my middle name. |
#107 |
Yes, luckily we have commonly available 0.1% resistors that take will tackle this at reasonable cost.
#108 | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Amplifier Simplicity and technology... | Boscoe | Solid State | 2 | 4th June 2012 08:47 AM |
simplicity vs fully active ? | Designated Marksman | Multi-Way | 13 | 4th June 2011 08:27 PM |
Purity and simplicity of amp design | lowtherdream | Tubes / Valves | 63 | 6th August 2008 09:06 AM |
Baffle simplicity yields sonic dipole benefit? | rick57 | Planars & Exotics | 19 | 6th October 2006 01:25 PM |
'Best' cost/simplicity/performance 10 W Single Ended Class A | npr | Pass Labs | 2 | 25th September 2006 10:48 AM |
New To Site? | Need Help? |
