Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#21 |
Then I'm off to the recycling place tomorrow :-)
.....Where the music comes to die. |
#22 |
#23 |
diyAudio Moderator Emeritus
Let's call it dutch wiring then
![]() Seriously: the dutch NEN1010 is the basis of many EU regulations.
It's only audio. Member of the non modular PCB design committee |
#24 |
The Dutch are not bad at darts as well--
The Mighty Micheal van Gerwen . |
#25 |
I prefer TO-247 or 263 transistors to replace TO3. Unless I have a heatsink already drilled for TO3. Drilling 4 holes accurately with my hand motor is not doable, IMHO. The plastic packages require 1 hole. Salvage motor drive or flat screen tv heat sinks will be pre-drilled for TO-247 or TO-263. Probably with long life silicon rubber pads already stuck to them.
The do-all of plastic output transistors is the MJL21193 pnp MJL21194 npn. Also avalable in prefix NJL and NJW and MJW, for reasons I can't determine from the datasheets. I use all four prefixes interchangeably, with .51 ohm emitter resistors to even current out.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey PV-1.3K, MMA-81502, Herald RA88a mixer, Steinway console, Wurlitzer 4500, 4300 Last edited by indianajo; 30th November 2020 at 01:00 AM. |
#26 |
Well, the electrical company had some stuff in the junk pile.
A good start I think. I put a fuse for size comparison. I'll check back regularly
#27 |
kmj - those are nice sinks. Wish I could find some lying around here. Best of luck with the rebuild.
Kevin
Ferret. - Gaya rules |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
A blast from the past .. PAPA1 | a.wayne | Pass Labs | 4 | 30th April 2010 09:06 PM |
Totally cool, blast from the past... | amt | Everything Else | 5 | 26th March 2010 04:34 AM |
pioneer sa 9800. blast from the past | burbeck | Solid State | 5 | 15th January 2008 03:03 PM |
Blast from the past! NEC602 6Xe 6Xi CD caddies for sale | sivalleydiyer | Swap Meet | 3 | 26th March 2004 11:54 PM |
New To Site? | Need Help? |
